Latest: sparrowdclxvi
Overall: 17139
Online Now [139]:
Visitors: 138
Today: 21341
Total: 113353331
Forums › The Car › 206 Problems › Creaking - Squeaky sound
jamie-38-206
PostPosted: Fri Mar 07, 2014 11:04 am Up
Hi,
The morning while parking the car I noticed a creaking / squeaky sound which appears to be coming from the back left wheel I think. Took car out to pick my child up from school and again noticed this sound while driving slow. I did how ever notice that the sound immediately when I pressed the brakes then re-appeared when moving again.
Anyone else had this sort of problem?
Many Thanks
PostPosted: Fri Mar 07, 2014 11:15 am Up
Well when the last time you checked your rear brakes and drums or discs?
jamie-38-206
PostPosted: Fri Mar 07, 2014 11:19 am Up
only bought the car a few months back. so have not had the chance to get them checked. Was thinking before I went to the mechanic if there was a caliper or something which could be greased?
luke079
PostPosted: Fri Mar 07, 2014 12:15 pm Up
Sounds like caliper is locked on take wheel off and see if you can easily take the pad out
PostPosted: Fri Mar 07, 2014 12:27 pm Up
it can be a locked caliper,or the brakes need replacement ,as it reached the metal.
aitch68
PostPosted: Sat Mar 08, 2014 11:54 am Up
Had the same fault on a 306 with rear disks.the rear o/s caliper was siezed solid.used loads of penetrating oil and a rubber mallet to free it off. That fixed mine for 6 months and a similar noise returned. That time it was the rear beam bushes that had perished. Would try the caliper first its easier to do.
Hope this is helpful
