Latest: Kifi69
Overall: 17183
Online Now [466]:
Visitors: 465
Today: 65858
Total: 144083723
Forums › The Car › 206 Talk › Who can Provide the 4 digits??Now I can do
PostPosted: Sat Mar 08, 2014 1:59 pm Up
Hello All,
I would like to ask if anyone in here can provide the PIN code ( 4 digits ),so that it can be used to program new key.
Thanx
Tim
mattymj
PostPosted: Sat Mar 08, 2014 2:17 pm Up
New ignition key?
PostPosted: Sat Mar 08, 2014 2:29 pm Up
mattymj wrote:
New ignition key?
Yes Smile
mattymj
PostPosted: Sat Mar 08, 2014 2:38 pm Up
I think u can do that with the key in the ignition? By holding a button!
mattymj
PostPosted: Sat Mar 08, 2014 2:41 pm Up
CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP )
1. Ensure all doors are unlocked using the .
2. Press and HOLD the large plip button while the LED flashes continuously for 20 seconds. After 20 seconds press the small deadlock button once while still holding the large button.
3. The LED will stop flashing.
4. Release the large button and the LED will light constantly.
5. Press the large button once and the LED will go out.
6. Open the door and hold the Plip near the Ignition switch and press the large plip button once.
7. Turn the ignition ON, wait 10 seconds and then turn the ignition OFF.
8. After 5 seconds the Plip should now operate.
206 PLIP MING SYNCHRONISATION—BSI
1. Insert the Ignition .
2. Press the small Black button.
3. Switch the Ignition ON
4. Keep the lock button pressed for 10 seconds.
5. Release lock button , switch ignition OFF and remove .
6. Close all doors and press the lock button 2 times.
NOTE : If PLIPS still do not work, start the vehicle and then turn OFF. Open and close the door, and check PLIP again.
mattymj
Unless this doesn't work on new keys!
PostPosted: Sat Mar 08, 2014 2:51 pm Up
Thank you for the helpful info Matty,but I'm asking for the 4 digits,the security code that is needed to program a new key using PP2000 Smile
mattymj
PostPosted: Sat Mar 08, 2014 3:06 pm Up
Ah no worries. Hope you get it sorted
PostPosted: Sat Mar 08, 2014 3:10 pm Up
Thank you Very Happy
PostPosted: Fri Mar 14, 2014 10:37 am Up
Bump!!
PostPosted: Sat Mar 15, 2014 10:09 am Up
Peugeot only. Costs 17.50
PostPosted: Mon Aug 03, 2015 6:21 am Up
Info:Now I can get the 4 digit security code if anyone needs them,all you have to do is send me the last 8 digits of the VIN,and you will have the 4 digits,it costs ( 35 GBP) .
Cheers,
Tim
PostPosted: Mon Aug 03, 2015 10:36 am Up
Its now free from peugeot mate
Sorry to be a pain....
PostPosted: Mon Aug 03, 2015 11:28 am Up
FREE Shocked
That's a result Very Happy
Take it they still ask for proof of ownership & id before handing over the code?
PostPosted: Sat Aug 22, 2015 5:10 am Up
No need to be sorry mate Smile
