Latest: jackrox1992
Overall: 17186
Online Now [852]:
Visitors: 851
Today: 239683
Total: 148375176
Forums › The Car › 206 Problems › Engine light question
206gt160
PostPosted: Sat Mar 08, 2014 3:34 pm Up
My alternator is yet to be changed to the 180 alternator and is not charging my battery, so i get a battery light coming on, when I've started my car after around five or ten seconds the engine management light comes on.
1. Will this be because the battery is not charging or would the engine management light not come on for this?
2. I also need a map due to the 180 bits fitted so could it be coming on due to over fueling etc?
I don't have a fault reader for the pug only the Audi (well I have pp2000 just can't fathom it lol.. Help) so due to this I can not yet find out what the code is.
Any ideas on the 2 above
PostPosted: Sat Mar 08, 2014 4:21 pm Up
Without having codes read,it will be like p**sing in the wind...so work on the PP2000,and make it work Wink
206gt160
PostPosted: Sat Mar 08, 2014 4:31 pm Up
I will try get it working
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
