Latest: morgan20
Overall: 17135
Online Now [563]:
Visitors: 562
Today: 14202
Total: 110566466
Forums › The Car › 206 Problems › car needs new rear brake line
206gt160
PostPosted: Mon Mar 17, 2014 3:58 pm Up
My car needs new brake lines fitting and my question is, can I make a new route for the lines or do they need to be in the original place for the mot?
Also when undersealing underneath a car the best thing "in my opinion" please tell me if im wrong.. but if there is rust spots I would sand down the rust first, yet most videos are showing just spraying over the rust.
PostPosted: Mon Mar 17, 2014 4:00 pm Up
You referring to the pipes over the fuel tank?
206gt160
PostPosted: Mon Mar 17, 2014 4:08 pm Up
Not the hand brake cables the actual caliper brake lines, I dont "think" they go over the fuel tank? I was considering running braided hose through the car and through the inner arch? You dont know what size the braided hose size is by any chance, ive read its 3/16
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Mon Mar 17, 2014 4:12 pm Up
Braided hoses would be a waste of time.
206gt160
PostPosted: Mon Mar 17, 2014 4:15 pm Up
Why would they be a waste of time. Do you mean because they flex where as the copper hose doesnt. Or price wise
206gt160
PostPosted: Mon Mar 17, 2014 4:16 pm Up
May be the ones that run over the fuel tank didnt get chance to have a proper look
PostPosted: Tue Mar 18, 2014 7:11 pm Up
Braided hoses inside the car? Massive effort and solid copper will giver better braking than braided. Braided are better than standard flexible hoses but the length of runs you will need in braided is an absolute waste of time, money and effort.
PostPosted: Tue Mar 18, 2014 7:14 pm Up
Remove the rust, treat with rust cure paint of your favourite brand, paint with anti rust paint of your favourite brand and then underseal. That is the real way to do it.
206gt160
PostPosted: Wed Mar 19, 2014 6:20 am Up
Worked on the pug yesturday and ended up cleaning the old pipe work, was just surface rust so now they're fully protected.
