Online Now [689]:
Visitors: 688
Today: 142123
Total: 146844652
Forums › The Car › 206 Problems › water coming in under door
Geforce
PostPosted: Thu Mar 20, 2014 4:13 pm Up
hi guys, I have water coming in from what looks.like under.the.door but im not sure exactly why.
Can someone help with this
cheers
20Drift
PostPosted: Thu Mar 20, 2014 4:16 pm Up
Have a look at the black seal that runs along the carpet - is it split at all?
Geforce
PostPosted: Thu Mar 20, 2014 4:25 pm Up
Water is collecting on the seal where the mould.for the.cup holders are in the door card, so if I open the door where the cup holder is is water if that makes sence
20Drift
PostPosted: Thu Mar 20, 2014 4:27 pm Up
Okay - open the door and have a look at the black rubber seal that runs around the hole which the door fits in to.
It's likely part of it has split and is letting rainwater in
Geforce
PostPosted: Thu Mar 20, 2014 4:31 pm Up
Ok will have a look tomorrow, will also post picture.
thanks
PostPosted: Fri Mar 21, 2014 2:50 am Up
make sure the drain holes is not blocked with dirt.
PostPosted: Fri Mar 21, 2014 2:56 am Up
Mine does that...on the rare occasions it gets wet. I just leave some kitchen roll stuff in the gap under the door pocket!
DanT
PostPosted: Fri Mar 21, 2014 3:10 am Up
Mine does it too...although it never seems to be much at all so im wondering if it kind of runs onto the carpet as i open the door?
Geforce
PostPosted: Fri Mar 21, 2014 12:35 pm Up
they are not block , water collects under the carmat if i dont keep on top of it Confused
RKOT
PostPosted: Fri Mar 21, 2014 12:41 pm Up
had this issue, found out someone had taken the door card out and had ripped the weather proofing sheet inside the door, this may be causing it
Geforce
PostPosted: Fri Mar 21, 2014 1:04 pm Up
do you mean the white sheet thats stuck on inside the doorcard?
PostPosted: Fri Mar 21, 2014 1:40 pm Up
Yes.
