Latest: Worthy967
Overall: 17143
Online Now [507]:
Visitors: 506
Today: 144746
Total: 115175688
Forums › The Car › 206 Problems › sluggish acceleration
sirrom40
PostPosted: Thu Mar 27, 2014 4:07 pm Up
I am at the end of my tether with 1.6 206 cc .. only had it two weeks 03 plate .. seems underpowered and foot is flat to the floor
then will pick up .. put on peugeot planet no faults . Changed all filters plugs . Still no improvement .. seems cant drive at low revs and always need to get up to 4000 revs to change gear .. seems like i have to drive it like a bloody rally car to get good drive .. help
PostPosted: Thu Mar 27, 2014 4:15 pm Up
Is the clutch slipping?
sirrom40
PostPosted: Thu Mar 27, 2014 4:18 pm Up
No not at all .. just slow to pick up .. alo accelerator pedal pushes to floor ..
Vexs
PostPosted: Thu Mar 27, 2014 5:29 pm Up
This may be of some intrest to you www.peugeot206cc.co.uk...f=4&t=6923
Seems unlikely for it to start now espicially as its an 03 but worth the read if you haven't seen this already
Mr-Tigger
PostPosted: Fri Mar 28, 2014 12:30 pm Up
also might be a long shot but have you checked that the throttle is actually opening up fully.....could just be a poorly adjusted cable Smile
PostPosted: Fri Mar 28, 2014 3:03 pm Up
Should be an electronic fly by wire throttle on this one as it will be the Bosch ME 744 system.
PostPosted: Sat Mar 29, 2014 4:21 am Up
What are the chances that it has recently had a cam belt change and the valve timing is wrong?
Might also be worth doing a compression test to check that everything is basically sound with the engine.
