Online Now [708]:
Visitors: 707
Today: 118643
Total: 146821207
Forums › The Car › 206 Problems › Cambelt kit help needed please
Andy206
PostPosted: Sat Mar 29, 2014 11:22 am Up
Hi all, im trying to order a cambelt kit for my 2002 206 1.4 8v petrol. However their seems to be two available, 108 teeth or 104 teeth, my question is which one do i need??? thanks in advance for any help
Anthonys206
PostPosted: Sat Mar 29, 2014 2:22 pm Up
There's also 2 different water pumps and 2 different tensioners. I'm sure you want the belt with 104 teeth, water pump with 18 teeth and the tensioner with the pin in it. I found this out the hard way.
PostPosted: Sat Mar 29, 2014 3:07 pm Up
Depends on the engine variant
TU3JP
108 DENTS LARG 17 - EXCEPT ALL ALCOHOL OR PETROL RON 95 (FLEX FUEL) EXCEPT K VEHICLE TECHNICAL DEPOLLUTION EXCEPT L4 VEHICLE TECHNICAL DEPOLLUTION EXCEPT IFL5 VEHICLE TECHNICAL DEPOLL (TAX INCENTIVE) EXCEPT TECH EMISSIONS L4 BASE VEHICLE
108 DENTS LARG 17 - TECH EMISSIONS L4 BASE VEHICLE UNTIL ENGINE 3666765 OR K VEHICLE TECHNICAL DEPOLLUTION UNTIL ENGINE 3666765 OR IFL5 VEHICLE TECHNICAL DEPOLL (TAX INCENTIVE) UNTIL ENGINE 3666765 OR L4 VEHICLE TECHNICAL DEPOLLUTION UNTIL ENGINE 3666765
104 DTS - ALL ALCOHOL OR PETROL RON 95 (FLEX FUEL)
104 DTS - TECH EMISSIONS L4 BASE VEHICLE SINCE ENGINE 3666766 OR IFL5 VEHICLE TECHNICAL DEPOLL (TAX INCENTIVE) SINCE ENGINE 3666766 OR K VEHICLE TECHNICAL DEPOLLUTION SINCE ENGINE 3666766 OR L4 VEHICLE TECHNICAL DEPOLLUTION SINCE ENGINE 3666766
TU3A
104 DTS
VIN + servicebox check will make sure you get the right parts.
If you don't have access to servicebox, PM me the last 8 of your VIN and I can tell you which one you need
Andy206
PostPosted: Sun Mar 30, 2014 4:02 am Up
thanks guys,changing the cambelt is the easy bit,it`s getting the right one that`s the bugger Smile
PostPosted: Sun Mar 30, 2014 4:31 am Up
TU3JP engine
Peugeot part 0816F2 104DTS Timing belt
Andy206
PostPosted: Sun Mar 30, 2014 4:37 am Up
Thanks Macca, i`m guessing my engine number is the one on my V5.?
