Online Now [529]:
Visitors: 528
Today: 156108
Total: 145461770
Forums › The Car › Solved 206 Problems › Judder but still performing ??
Forum Index › Solved 206 Problems
206Info_SW_Scots
PostPosted: Tue Dec 10, 2013 2:19 pm Up
Hi,
New exhaust manifold and oxygen sensor in Aug. much smoother after that. 107,000 miles.
Been perfect since 2006 and 10,000 miles but since Oct. I get an intermittent juddering at 2000 revs after 10mins on the motorway. It judders but there is still electrical power and the revs don't drop on the rev. counter and it maintains speed. Still good MPG.
If I commute 10mins and avoid Motorways - revs above 2K - then there is no juddering and no Engine Management light.
It has been getting more frequent and noticeable. If I drive for an Hour it only happens every 10-15mins. Not all the time when driving. It doesn't happen If I sit in 3rd eg high revs.
Tried redex fuel and injector cleaners. No real change.
I cleaned the butterfly/air cleaner passage with Carb. Cleaner. Not sure it made any difference. I have read about the throttle body etc but have not done anything to clean the sensors etc. If I can get the car up I will replace the fuel filter, If mine is on the outside under the body, as it;s an easy job.
I'm thinking of taking it to an Auto Electrician and getting him to fault code it and check the plugs/coil pack/leads.
Any ideas ?
Nick
206 SW 55 Plate - Happy Owner
PostPosted: Tue Dec 10, 2013 2:35 pm Up
well it's a good start to have fault codes read before you replace anything,and since you got the EML on and off,then you must have fault stored.
206Info_SW_Scots
PostPosted: Tue Dec 10, 2013 2:55 pm Up
Thanks. Just reluctant to go to a garage as I had an Espace that ended up costing me 1000s of pounds and it was never fixed !
I know the Autoelectrician so will go and see him tomorrow.
Just been out at the car. 1.4 petrol manual. Has the fuel filter/pump under the driver side rear passenger seat. So can't readily see the fuel filter or easily replace it.
I think it's a sensor or coil pack. Certainly a lot to take off to access and check the spark plugs ?
206Info_SW_Scots
PostPosted: Tue Dec 10, 2013 3:30 pm Up
Well the coil pack replacement looks like a 5min job. If that's what it turns out to be. No special tools etc.
And I now know how to get the plugs out to check them too.
PostPosted: Fri Dec 13, 2013 12:16 pm Up
any further info. on what you got?
206Info_SW_Scots
PostPosted: Sun Jan 19, 2014 8:29 am Up
16mm plug socket, hard to find on the high street/retail park, bought. Just giving the engine an hr to cool then plug check and inspection.
As it's still only juddering after 5-10mins driving I think it's a sensor. The fuel pump - under the drivers side passenger seat - primes up when the keys are in the ignition.
206Info_SW_Scots
PostPosted: Sun Jan 19, 2014 12:34 pm Up
All plugs fine. Ran same as before I checked them. So next step garage. Hopefully autoelectrician can diagnose quickly.
I think it's a sensor fault as it runs smoothly till 5-10 mins.
206Info_SW_Scots
PostPosted: Sun Jan 19, 2014 1:18 pm Up
After reading the Haynes manual, my accelerator pedal cable seems to have lots of play once the cam is sitting back in the idle position ?
Does this effect idling or when I'm not accelerating when driving ?
206 1.4 2005 107,000miles.
206Info_SW_Scots
PostPosted: Sun Jan 26, 2014 10:00 am Up
www.flickr.com/photos/79734192@N03/
Just checked all connections I could reach for good connection, dirt, corrosion etc. Then I found a female 3 pin connector under the front below the wiper and about 20mm from a loom. No other connector near it. Pic in the link above.
Trawled the hatnes manual pics to see what it is. Im hoping it's for another model.
I cleaned - carb cleaner -into the breather opening, on all the engine side of the carb/throttle body, breather hose connections. Seemed to make it run much smoother at idle.
I have bought a code reader, bluetooth compatible, obd 2 and has scanning capabilities. So can drive the car and when the juddering starts, the phone will show readouts etc.
206Info_SW_Scots
PostPosted: Sun Feb 02, 2014 11:41 am Up
Cleaned the maf sensor. It was covered in black light oil. Cleaned off easily. Car drove more sweetly and quietly until the usual 80degs or 10mins then the now normal juddering. It's also on it's first fuel tank of shell v power.
Hopefully my obd scanner arrives soon and some light will be shed....
206Info_SW_Scots
PostPosted: Tue Feb 04, 2014 2:04 pm Up
So just drove home with obd 2 scanner connected.
Smooth driving from start and after 80deg coolant temp, the fuel system changed. From
'Closed loop, using o2 sensor for fuel mix'
to juddering starting and 'open loop due to system failure' on the component status.
The other seems fine, air intake pressure is reading smoothly up and down when normal throttle up and down.
This is with the Torque app.
No data comes from the fuel trim or maf sensor. Are these faulty ?
Im getting air intake pressure, does that come from the maf ?
206Info_SW_Scots
PostPosted: Tue Feb 04, 2014 4:41 pm Up
Success !
Using the wee OBD 2 - ELM 327 Scanner/Reader
The TORQUE app was good at showing various readings and seeing if sensors were giving reasonable readings etc. But it did not read CODES.
Downloaded OBD Car Doctor free app and bingo codes came up. Also the MAF reidngs was Ok. Torque app. never showed that. Car Doctor showed eachs ensor or reading on it's own so good for that.
P0210 Injector Circuit Open Cyl 1
20140204_200020.jpg by Scotstechy, on Flickr
So gonna order a new injector and fit this weekend. If that cures it I will post up so this thread can be moved to SOLVED.
Really good vlaue for £7 to scan codes etc, well worth having the bluetooth one so you can drive the car witht he app running for live data.
206Info_SW_Scots
PostPosted: Wed Apr 02, 2014 2:49 pm Up
Update.
As self diagnosed, cylinder 1 injector replaced. Now super smooth !
206gt160
PostPosted: Wed Apr 02, 2014 4:33 pm Up
What year was your 206?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
206Info_SW_Scots
PostPosted: Wed Apr 16, 2014 9:08 am Up
Hi,
In my signature when I post, 2005.
Do you have a similar fault/problem ?
