Latest: lio94
Overall: 17181
Online Now [157]:
Visitors: 156
Today: 8335
Total: 141259099
Forums › The Car › 206 Problems › Wiring Identification Help.
Vexs
PostPosted: Wed Apr 16, 2014 3:41 pm Up
So noticed these two connector ends located behind the front passenger side headlight.
These weren't plugged in to anything so wondering what the hell there for?
I suspect many of the 206's share a similar wiring setup and simply ends don't get cut off and left.
Pictures not great but will get some more tomorrow of where these go to if required.
206Info_SW_Scots
PostPosted: Thu Apr 17, 2014 1:39 am Up
I have the right hand one, but with a grey cover, sitting behind the passenger headlight too. Mine is. Sw 1.4 s.
Never seemed to have done any harm, I have another non connected terminal further in under the wiper area, again not seem to matter. Someone on the forum that one was an alarm lead.
206 SW 55 Plate - Happy Owner
PostPosted: Thu Apr 17, 2014 6:20 am Up
The big one could be a fog light connector.
206Info_SW_Scots
PostPosted: Thu Apr 17, 2014 6:24 am Up
Hmm, yes it could reach low enough.
DREWDEN
PostPosted: Thu Apr 17, 2014 7:55 am Up
To throw spanners into the works i have fog lights fitted, but have a spare brown 2 pin connector not plugged into anything.
My assumption is different wiring looms for different year and engine size,
plexed, multiplexed.
206 2ltr Hdi glx 53 plate
PostPosted: Thu Apr 17, 2014 11:14 am Up
The 3 pin is for the crystal twin H7 headlamps.
The 2 pin is for front fog lamps.
If you look behind drivers side headlamp you should find the other pair of connectors for that side also hiding away.
Basically its cheaper to make one standard wiring loom with all the plugs on then to have several different spec looms with different amounts of plugs.
Vexs
PostPosted: Thu Apr 17, 2014 3:47 pm Up
Yer forgot to mention there is an identical pair on the drivers side too.
Ok so basically means when I get round to swapping the frosted lens over its just plug and play?
PostPosted: Thu Apr 17, 2014 3:57 pm Up
You need to change the BSI configuration set up with Peugeot Planet from FROSTED to CRYSTAL headlamps.
If you don't change the setting then the dipped beam will go OFF when you select main beam.
MOT failure IF the tester is on the ball & also its pointless changing the lights & not having them working correctly.
Vexs
PostPosted: Thu Apr 17, 2014 4:18 pm Up
Thanks for the heads up Thumb Up
PostPosted: Fri Apr 18, 2014 4:26 am Up
You can also bodge it to work correctly with relays & wiring adaptors as i'm sure others on the forum will encourage.
BUT what's the point when the car already has all the correct relays & wiring fitted, it just needs a small BSI set up tweak with Planet to tell it higher spec headlamps are now fitted.
