Latest: airmastertapes
Overall: 17133
Online Now [187]:
Visitors: 186
Today: 130677
Total: 106664243
Forums › The Car › 206 Problems › 2003 fuse layout
2003 fuse layout
Go to page Previous  1, 2
Jooo
PostPosted: Tue Apr 29, 2014 6:51 am Up
Hi Drewden. No luck with the BSI reset. Tried it a few times as suggested but no luck.
Think I might have to find a car spark to do what you had done to yours. I live in Bristol so Yorkshire is a bit far away.
Or not bother and just drive during daylight hours!
DREWDEN
PostPosted: Wed Apr 30, 2014 7:07 am Up
No probs, obviously you will need to fix it before MOT time, will you kindly report back please what the fix was, just interested to know, also it will help other people.
206 2ltr Hdi glx 53 plate
Jooo
PostPosted: Wed Apr 30, 2014 12:25 pm Up
Thanks Drewden. I will post the fix (hopefully) as soon as I get it sorted. MOT mid June!
Jooo
PostPosted: Sat May 10, 2014 3:59 am Up
Hi all,
Connected a length of wire from the working rear side light and connected it to the non working side and it worked a treat! All side lights and number plate lights are now working. Took around 30 minutes and most of that was trying to find the right wires to connect to as they are slightly different both sides.
Hope this helps someone else.
Thanks everyone.
mtempsch
PostPosted: Sat May 10, 2014 5:40 am Up
Jooo wrote:
Hi all,
Thanks everyone.
So it would appears the fault lies 'upstream' from where you patched into (where did you?) that circuit.
Silvermetallic 2004 206 RC
Jooo
PostPosted: Sat May 10, 2014 12:53 pm Up
I used a 12v circuit tester to locate the side light feed from the working side and connected it to the opposite side. Worked perfectly.
Page 2 of 2
