Latest: jackrox1992
Overall: 17186
Online Now [691]:
Visitors: 690
Today: 47342
Total: 148009972
Forums › The Car › 206 Talk › looking for some info here
Forum Index › 206 Talk
craigmuir
PostPosted: Sun May 04, 2014 11:21 am Up
hi just bought a wee 206 the run around in looking for info or prices on the advisory items section as I dont understand them. 1 offside track rod end ball joint has slight play. 2 nearside front lower suspension arm rubber bush deteriorated but not resulting in excessive movement. 3 nearside rear suspension arm synthetic bush deteriorated no excessive movement. 4 offside rear suspension arm bush deteriorated but not resulting in excessive movement. 5 advise all pipes on vehicle brake pipe slightly corroded. 6 advise age related corrosion on underside and outer sills of vehicle. any info would be great thanks Whistle... Whistle...
sicskate
PostPosted: Sun May 04, 2014 12:48 pm Up
Trade Rating: +13
1, track rod end needs replacing
2, wishbone needs replacing
3+4, rear beam is almost shoot
5, brake pipes are corroded
6, surface rust is setting in.
307 1.4hdi Smile
craigmuir
PostPosted: Sun May 04, 2014 1:37 pm Up
so will it be expensive to repair then?
iainlovatt
PostPosted: Sun May 04, 2014 1:39 pm Up
A rear axle will set you back £250-300 depending on how you do it, it would be more if you get a reconditioned one.
(My Garage)
craigmuir
PostPosted: Sun May 04, 2014 2:04 pm Up
ok thanks
Tolkienfan001
PostPosted: Sun May 04, 2014 2:05 pm Up
Trade Rating: +13
www.axledirect.com/peugeot_206/
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sun May 04, 2014 2:10 pm Up
Shocked you haven't got one for sale Shocked
