Posted: Sat May 10, 2014 12:33 pm |
Hey, Im looking at the steering wheels mines getting worn down quite badly, I like the look of the 206 GTi wheel some on ebay say they fit 2001 onwards.. but not sure if they know or not.
(Peugeot 206 1.4 8v 1999 T Reg)
If you could give me a link with Wheel and Airbag under £35 if im lucky.. would be appreciated
However I came across this one..?
www.ebay.co.uk/itm/Peu...233a273535
Posted: Sat May 10, 2014 12:37 pm |
That Ebay one wont fit your car, that wheel is multiplexed / clip on airbag type.
Posted: Sat May 10, 2014 12:38 pm |
| MrBSI wrote: |
| That Ebay one wont fit your car, that wheel is multiplexed / clip on airbag type. |
Ah okay thanks for that, which ones will? thanks.
Posted: Sat May 10, 2014 2:44 pm |
The one you are after is where the air bag screws in as apposed to clips in like BSI already stated.
Screw on = pre plexed. Clip on = multiplexed.
I also believe that the pre-plex has round holes at the back where as the multiplex has rectangles.
I done some digging and found this GTI steering wheel with the screw on airbag type. This will fit yours, but just double check with the seller first.
www.ebay.co.uk/itm/Peu...1334wt_959
