Latest: ArtistKS
Overall: 17145
Online Now [52]:
Visitors: 51
Today: 9721
Total: 116025092
Forums › The Car › 206 Problems › Idling issue?
Idling issue?
LNHalton
PostPosted: Sun May 11, 2014 12:29 pm Up
Me again.. Not sure if this is an issue or if it'll be fixed if I get the timing sorted... But the car ('99 GTI) is idling at around 750rpm (first line below 1k revs) and when it's just sitting idling the needle rises and falls ever so slightly and I can hear it in the engine aswell.. Just wondering if it's an issue that needs attention?
1999 2.0 GTI in Blaze Orange with Black roof.
Mr-Tigger
PostPosted: Sun May 11, 2014 12:55 pm Up
welcome to the club, had this issue for over a year,doesnt seem to harm performance. careful who does what as there can be a million causes:
plugs
coilpack
timing
MAP sensor
Air/vacuum leaks
I've had all of the above done/changed and it still persists (53 plate 136 GTi)
PostPosted: Sun May 11, 2014 1:41 pm Up
try cleaning the throttle body,and see how things goes.
PostPosted: Sun May 11, 2014 2:52 pm Up
Anyone tried any ECU update?
Mr-Tigger
PostPosted: Mon May 12, 2014 3:46 am Up
done that timon. and addaz thats the one thing i've now been debating, or i was, a remap or map from PUG but at £200+ its an expensive "what-if"
LNHalton
PostPosted: Mon May 12, 2014 1:55 pm Up
Hopefully I'll be getting the timing sorted soon so I'll see if it resolves after that, if not, how would I go about cleaning the throttle body? Is there a thread on here? (I'm not really experienced with cars)
LNHalton
PostPosted: Tue May 13, 2014 11:23 am Up
Now it's started to idle above 1k on start up, then after the engine warms up a little the idle drops gradually...
David1156
PostPosted: Tue May 13, 2014 11:47 am Up
Mine does this too. It usually drops after about half a minute.
Current: Albi Blue Clio 197
