Latest: sparrowdclxvi
Overall: 17139
Online Now [111]:
Visitors: 110
Today: 40402
Total: 112378692
Forums › The Car › 206 Problems › A few 206 probs
A few 206 probs
oldfart
PostPosted: Sun May 11, 2014 4:55 pm Up
Wifes car 206 1.6iGLX auto 2002
After doing a rear pad change have started getting faults appear as follows:
Initial fault ABS fault
Removed and cleaned all ABS wheel sensors and surrounding areas
Then Braking problem
AirBag fault
AntiPollutant fault
Speedo stops working
Alarm activated then battery died. No hint of a problem prior to this.
Had battery/alternator checked and all ok.
HELP!!!!!
PostPosted: Sun May 11, 2014 11:19 pm Up
Dodgy earth?
oldfart
PostPosted: Mon May 12, 2014 1:32 am Up
As I thought. But which one???? Weekend of searching I guess.
Will keep you informed
VorTechS
PostPosted: Mon May 12, 2014 3:26 am Up
Staff - Vortechs
The one that tends to go most often, is the one between the engine / gearbox because they were never made long enough ....
oldfart
PostPosted: Mon May 12, 2014 8:35 am Up
Thanks for your replies folks.
Found a guy local to me with Planet Software and for the princely sum of £40 did a scan for me this morning. Nothing serious on live scan just ABS fault and a glitch on fuel potentionmeter.Wiped the codes then took it for a short run and all that came back was ABS fault.
Offside front and rear sensors suspect. Rear was installed upside down by the fool that cleaned the sensors (I wonder who that was).
Can't work out what the total power out was about,but will deal with that if and when it occurs again.
Unless of course the car bursts into flames. I may be an old fart,but I can still run like a greyhound when I need too!!!!
