Online Now [245]:
Visitors: 244
Today: 51814
Total: 142673183
Forums › The Car › 206 Talk › any one fitted TURBO 5000 ELECTRIC TURBOCHARGER
19Connor92
PostPosted: Mon May 12, 2014 11:48 am Up
www.ebay.co.uk/itm/TUR...0978747047
PostPosted: Mon May 12, 2014 11:53 am Up
19Connor92 wrote:
http://www.ebay.co.uk/itm/TURBO-5000-ELECTRIC-TURBOCHARGER-TURBO-SUPERCHARGER-KIT-FOR-ALL-CARS-/320978747047
Do you have the word MUG tattooed on your forehead? Wink
19Connor92
PostPosted: Mon May 12, 2014 12:06 pm Up
No, its engraved
PostPosted: Mon May 12, 2014 12:11 pm Up
19Connor92 wrote:
No, its engraved
You sound like the perfect person to buy this product then Wink
David1156
PostPosted: Mon May 12, 2014 12:13 pm Up
I have mate. The gearbox couldn't handle all that power though so i've had to take it off until I get an uprated clutch and gearbox.
Current: Albi Blue Clio 197
Barking
PostPosted: Mon May 12, 2014 12:22 pm Up
Negative feedback rating: Do not buy this does no work and messes with you mas ecu sensor e***1 ( 43Yellow star icon for Feedback score between 10 to 49) 10-May-14 11:19
◾Reply by proven_performance_international (10-May-14 16:04):
Pls read instruction carefully. these r compatible with MAF and MAP.Here to help
ELECTRIC TURBOCHARGER SUPER CHARGER UNIVERSAL FITMENT (#320900467174) £149.99 View Item
I got a dig bick.
You that read wrong.
You read that wrong too.
206gt160
PostPosted: Mon May 12, 2014 1:26 pm Up
Just don't do it, for one it will not work because it will disturb the airflow and also if the fan snaps and plastic and metal goes into your engine you will have a very unhappy engine
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
20Drift
PostPosted: Mon May 12, 2014 1:47 pm Up
It's been mythbusted and it doesn't do jack really
