Latest: jackrox1992
Overall: 17186
Online Now [659]:
Visitors: 657
Members: 1
Today: 80491
Total: 148612487
Forums › The Car › 206 Problems › 2.0 GT problems with RPM
Misio
PostPosted: Sun Apr 27, 2014 7:57 am Up
Hi guyz, i have big problem with my engine for few weeks... It started to stop on rpms without reason... its always like 2000rpm and after 2-3s it drops properly... It happens only when im using clutch. When im on neutral gear it wont happen.... Sorry for my language but im from poland and i dont know such mechanic vocabulary...
here is video
www.youtube.com/watch?v=GJmpzK2_UXI
I have changed TPS and idle control valve and nothing changed...
doski
PostPosted: Sun Apr 27, 2014 10:00 am Up
maybe check the potentiometer its on the throttle body (the bit with the inlet butterfly valve) its on the other side to the idle control valve the throttle cable is attached to it.
unscrew it and see if anything looks broken mine had smashed inside and as a result the car was running on like a default rpm which was a solid 2000rpm
Misio
PostPosted: Sun Apr 27, 2014 10:26 am Up
Today i changed it to potentiometer from other s16... i have whole throttle body from other s16 which was all ok... 2morrow i think i will just swap my throttle body with this one...
Misio
PostPosted: Mon Apr 28, 2014 5:37 am Up
So i swapped all the sensors from the throttle body. I also cleaned Map and throttle body and nothing changed... I noticed that when the engine is cold everything is ok but when it gets hotter the problem gets bigger...
Misio
PostPosted: Tue May 13, 2014 4:26 am Up
Problem is still there....
America
PostPosted: Thu Aug 07, 2014 5:22 am Up
Still having a problem? Did you check your coil pack?
