Online Now [177]:
Visitors: 176
Today: 32593
Total: 138822958
Forums › The Car › 206 Problems › Very annoying
Very annoying
2004pug20611
PostPosted: Fri May 09, 2014 3:13 pm Up
Hi guys took my 206 1.1 54 plate to my garage I use and had both side lights changed ... I saw them both working and it has been 3 days and they have gone again I have took the bulbs out and checked with a volt meter and they are providing a current but after 3 days brand new bulbs from my Peugeot dealer have stopped working ... Has anyone else had this problem and know why it happened and how to fix it.
Cheers in advance Jamie t
pug_206_uk
PostPosted: Fri May 09, 2014 4:12 pm Up
do you have any water leaking in as this could cause them to blow or you may have a snag in the wire so when its damp it will blow.
2004pug20611
PostPosted: Fri May 09, 2014 4:37 pm Up
No water leaks I know of he is booked in on Thursday so if I can't figure it out or nobody knows then its gna be a lot of diagnostics needed
pug_206_uk
PostPosted: Fri May 09, 2014 4:46 pm Up
check the wiring around the headlight could be a broken wire or may be the headlight internally
Peugeot 206 1.4 HDI - July 2013 - Present
2004pug20611
PostPosted: Fri May 09, 2014 5:10 pm Up
I'll check first thing tomorrow tad bit dark now lol
pug_206_uk
PostPosted: Tue May 13, 2014 4:22 pm Up
How did you get on?
DMGBADB1
PostPosted: Wed May 14, 2014 5:07 am Up
I changed my sidelight bulbs monday and found both not working when I got home. Then I checked the bulb holder and found one was very brittle. And a loose fitting. I just twiggled with the bulbs until they both came on. I checked it last couple of days and seem ok now. But I will be looking for newer parts for it.
206 1.4, hdi, 2002
2004pug20611
PostPosted: Thu May 15, 2014 5:13 am Up
Had to replace both lights as it was same problem as dmgbadb1
pug_206_uk
PostPosted: Fri May 16, 2014 5:09 am Up
206 1.4, hdi, 2002
glad to hear you have sorted it
