Latest: lio94
Overall: 17181
Online Now [341]:
Visitors: 340
Today: 16318
Total: 141656032
Go to page Previous  1, 2, 3 ... 28, 29, 30, 31, 32, 33  Next
PostPosted: Mon Apr 21, 2014 11:47 am Up
220lb ft??? from a N/A 2 litre engine?
macj
PostPosted: Mon Apr 21, 2014 12:42 pm Up
Edward wrote:
220Nm??? from a N/A 2 litre engine?
I cant wait to see the figures..... Charlie is fairly confident he can get it
PostPosted: Mon Apr 21, 2014 2:14 pm Up
Even to get over 90lb ft per litre is doing extremely well so 110lb ft per litre...you'd need a miracle!
macj
PostPosted: Sun May 25, 2014 2:12 pm Up
Bit of an update on engine progress.
So far the crank is finished, fully knife edged and a load of weight gone.
Billet steel flywheel purchased from Pug1off
Billet alloy crank pulley from Pug1off
Custom Cams from Piper with an approx 288 profile made for us by the man himself
Cylinder head further modified with 2mm bigger inlet and exhaust valves. The biggest issue here is the cams have too bigger lift for the springs. The solution is to fit custom springs and machine the spring seats to fit. The decision to fit hydraulic lifters has been suggested by Piper themselves as there may be issues with fitting solids.
Dummy build was being done last week to see if the pockets were big enough in the pistons.
Next step is to do the machining and final build, set up the cams and refit the engine in the car if everything fits. Weld up the engine mounting points and send it off to the rolling road....... all before FCS Surprised
usher
PostPosted: Sun May 25, 2014 3:49 pm Up
sounding good and expensive lol, glad its coming together
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sat May 31, 2014 12:45 pm Up
Fitted the engine last night and took the car to Matt at Mtech for mapping today...... will be picking it up on Friday ......if it don't go bang Shocked
macj
PostPosted: Sat May 31, 2014 12:48 pm Up
Schumi wrote:
Be careful with oil pump. It can be explode at 9000 rpm. Lots of French guys know this problem. My GTI180 Turbo friend lost oil pump 2 times.
An update for you Schumi.... I have found a manufacturer of an upgraded oil pump for the EW10J4 and S engines........ wider rotor and made of stronger stuff..... I have one fitted in my new engine and have another pump coming..... Wink
AWK-53
PostPosted: Wed Jun 04, 2014 2:01 pm Up
Would you mind saying where from and cost as maybe interested in a pump
macj
PostPosted: Wed Jun 04, 2014 3:06 pm Up
I will post up all details when the other pump arrives with me. I will photograph it and provide spec. I will have an accurate price when I have an idea of quantity order
Schumi
PostPosted: Wed Jun 04, 2014 4:48 pm Up
Is that company from France and name contains rally ? Very Happy Dont complete name if you know.
2005 206 RC RED
macj
PostPosted: Thu Jun 05, 2014 8:22 am Up
UPDATE from roller session. timing Belt came off at 4000 rpm and am waiting on outcome...... dont hold out much hope of a good outcome
usher
PostPosted: Thu Jun 05, 2014 10:36 am Up
bad times hope its not a full rebuild Crying or Very sad
project thread WIP
garage
FAQ
206 gti firedance
PezHdi
PostPosted: Thu Jun 05, 2014 11:27 am Up
Ahhhhh s**te, Sad :( Sad
EXL Pez
AWK-53
PostPosted: Thu Jun 05, 2014 11:49 am Up
Sorry to hear that Crying or Very sad
PostPosted: Thu Jun 05, 2014 12:18 pm Up
Oops. Sympathies. That flywheel is too nice the be hidden in a bell housing.
Page 29 of 33
