Online Now [209]:
Visitors: 208
Today: 32177
Total: 143230369
Forums › The Car › 206 Problems › GTi lost power after 5000rpm
W573ADS
PostPosted: Fri May 30, 2014 3:00 am Up
Hey guys, slight problem on my GTi 138,
All was fine before and then started losing power after 5000rpm in all gears, more noticeable in the higher gears as it feels like you've let off the accelerator Sad
It also seems a bit lumpy when it does it, it will carry on all the way through the problem just very slowly
It didnt seem too bad at first but now its getting really bad
I serviced it the other day as was hoping it was that but still no better.
I dont know if this has anything to do with it but its been tapping/rattling under heavy acceleration since i had it was hoping it was the manifold problem thats common as im changing that soon
Any ideas?
Mods on the car atm are: decat, middle box removed, EGR blanked
PostPosted: Fri May 30, 2014 3:35 am Up
Surely if the egr is removed the ecu light will be on?
W573ADS
PostPosted: Fri May 30, 2014 4:25 am Up
The ecu light is on due to the decat and not the EGR already scanned it, it only comes on now and then because of the decat
PostPosted: Fri May 30, 2014 9:35 am Up
Lambda sensors removed? Could be a fueling issue.
W573ADS
PostPosted: Fri May 30, 2014 10:05 am Up
Im pretty sure it was fine after the decat though, and lambda sensors are still in place
heyziq
PostPosted: Fri May 30, 2014 10:52 am Up
check couil pack and spark plug
heyziq.com
PostPosted: Fri May 30, 2014 11:51 am Up
Lambda are there but they won't be reading right from the decat. You need to check the voltage on them and your fault codes.
W573ADS
PostPosted: Sat May 31, 2014 5:49 am Up
The part thats getting me is it was fine after the decat though, im reading the codes today and will get back to you.
Spark plugs were changed saturday when i serviced it.
Im thinking im gonna end up doing a full rebuild soon as the tapping is really annoying and cNt be healthy, i think its coming from the valve spring/valves/valve buckets. Sad
Another thing i brimmed the tank yeaterday and the fuel gauge was reading just under full even though it was upto the cap, then when driving it seemed to use alot more than it normally does..... Cant see a leak though
PostPosted: Sat May 31, 2014 5:52 am Up
Exactly, over fuelling I'd say.
W573ADS
PostPosted: Sat May 31, 2014 6:51 am Up
Any way to sort that? Maybe one of them lambda sensor extender things
PostPosted: Sat May 31, 2014 7:02 am Up
Known issue, it's the hydraulic tappets on the early engine's like yours.
W573ADS
PostPosted: Sat May 31, 2014 9:35 am Up
Expensive?
PostPosted: Sat May 31, 2014 9:41 am Up
W573ADS wrote:
Expensive?
Depends on your skills with the spanners, would be a new set of hydraulic tappets.
Apparently there only designed to last 40k miles according to Peugeot UK customer services Laughing
W573ADS
PostPosted: Sat May 31, 2014 3:28 pm Up
Im a truck mechanic by trade so i would say pretty good with the spanners, heard bad things about the belt tensioner on these, is it much of a problem to do or just blood sweat and tears Smile
PostPosted: Sat May 31, 2014 10:27 pm Up
Easy to work on, nothing out of the ordinary.
