Latest: cogeim7
Overall: 17185
Online Now [739]:
Visitors: 739
Today: 172884
Total: 147284815
Forums › The Car › 206 Problems › Radio problem
Radio problem
Johnnybrennan20
PostPosted: Sun Jun 01, 2014 11:42 am Up
Ok so I got my Pug 206 in September 2013. I got a radio off my uncle and I didn't realize two wires were exposed and they touched. Ever since then the radio wont work. I have two aftermarket radios and both wont work. I've tried the radio in my dads car and its still working so it's not fried. The standard radio that came with the car does work, however, it asks for the code everytime I switch on the car. No fuses are blown as I replaced every fuse to test this (under the bonnet and the one inside the car). The other thing is that it stores the stations on it so I'm not sure what it could be?
In the picture I'm attaching I get voltage from every single wire apart from the yellow and green one which I think could be the constant wire. Thanks for any input and solutions anyone can give!
MrRichmond1995
PostPosted: Sun Jun 01, 2014 12:23 pm Up
Well the green wire is earth so you wont see any voltage off of that and the red should be permanent going by a wireing diagram I have.
Double check all of your fuses as its sods law you have missed one, I did and my whole car wouldn't start!
Check fuse 4 which should be a 20 amp fuse and fuse 15 which should be a 15 amp fuse.
Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
Johnnybrennan20
PostPosted: Sun Jun 01, 2014 12:26 pm Up
I'll go out now and double check. Well it wont be double it'll be my 50th time haha. There is voltage off the red wire so if it's not the fuse, not the radio and not the wire... what could it be? Thanks
macj
PostPosted: Sun Jun 01, 2014 1:40 pm Up
Check for an inline fuse in the radio wiring loom. remember that the radio has memory from the permanent live(red) and ignition live from the other feed..... possibly the orange(not 100% as I don't do radios in cars)
Johnnybrennan20
PostPosted: Sun Jun 08, 2014 7:02 am Up
This is just a strange one as nothing seems to fix it! The inline fuse. Are you referring to the one inside the radio itself? If it is that which you are talking about then it's not that and it wouldn't be either because the stock radio was working perfect until the two wires touched but now it needs the code Everytime I turn it on.
MrRichmond1995
PostPosted: Sun Jun 08, 2014 10:26 am Up
Johnnybrennan20 add me on facebook and I will see if I can sort this for you
www.facebook.com/MrRichmond1995
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Sun Jun 08, 2014 11:48 am Up
Why does he need to add you on Facebook? You could help him on here and then others might be able to benefit in the future.
mtempsch
PostPosted: Sun Jun 08, 2014 1:08 pm Up
Johnnybrennan20 wrote:
O I have two aftermarket radios and both wont work. I've tried the radio in my dads car and its still working so it's not fried. The standard radio that came with the car does work, however, it asks for the code everytime I switch on the car.
No matter how you measured, this does sound like no power on the constant 12V line... Reasons:
1) Stock radio working but keeps asking for code (I'd guess it also forgets radio station presets?)
2 ) Aftermarket HUs not working - these typically have the constant and ignition reversed compared to the stock unit, and they draw main power for operation from [their] switched 12V, ie the cars permanent line.
Silvermetallic 2004 206 RC
Johnnybrennan20
PostPosted: Sun Jun 08, 2014 4:53 pm Up
No thats the strangest part its remembering the stations?!
The aftermarket radio was working until the wires touched I was pushing the radio back into place and the wires behind it sparked
