Forums › The Car › 206 Talk › GTi flywheel question |
Posted: Tue Jun 03, 2014 1:07 pm |
Is the GTi 137 and GTi 180 flywheel the same????
Posted: Tue Jun 03, 2014 1:20 pm |
Different part numbers.
No idea if there interchangeable.
Posted: Tue Jun 03, 2014 9:32 pm |
I always thought the 180 had a lighter flywheel than the 137. Not 100% on it though.
Posted: Wed Feb 24, 2016 8:50 am |
I've fitted the gti180 flywheel to mine the flywheel is definitely lighter
Posted: Wed Feb 24, 2016 12:29 pm |
Would be interesting to know the difference.
