Latest: Beduff1977
Overall: 17134
Online Now [972]:
Visitors: 971
Today: 174455
Total: 107576072
Forums › The Car › 206 Problems › date and time display
kaylee
PostPosted: Sun Jun 08, 2014 10:43 am Up
Hello. I am new to this forum and being a girl have never done anything like this before. I have recently started doing a job which requires driving from house to house, engine on engine off all day. I have now noticed that my date and time display now does not go off when the engine is off. It remains on all the time but is not draining my battery as the car starts fine every morning. It also no longer knows the outside temperature and comes up with dashes for this. Any idea what the problem could be? X
20Drift
PostPosted: Sun Jun 08, 2014 10:56 am Up
What year is your car?
If it's newer than 2002, it's most likely just the BSI (controls your car systems) is staying on. This is normal. It stays on for about 2 minutes after you remove the keys from the ignition, then turns off.
RE the temperature display - most likely a faulty temperature sensor, which is located in your mirror (see below)
kaylee
PostPosted: Mon Jun 09, 2014 5:17 am Up
You see that's the thing, it used to go off after 2 minutes now it remains on all the time. It doesn't go off. It's not longer lit up vert bright either it's very dull. It's a 2004 x
DREWDEN
PostPosted: Mon Jun 09, 2014 11:56 am Up
Does the car go into Economy Mode when its parked up for more than half hour.
206 2ltr Hdi glx 53 plate
kaylee
PostPosted: Mon Jun 09, 2014 4:27 pm Up
It does go into economy mode because it will turn the stereo off after a while but this has no effect on the date and time display. My car has currently been parked up outside my house, locked up, for about 1 and a half hours and the display is still on. X
