Online Now [606]:
Visitors: 605
Today: 66295
Total: 145372070
Forums › The Car › 206 Problems › air con how does it work?
omega
PostPosted: Fri Jul 04, 2014 3:39 pm Up
1998 1.4 lx
how does the aircon work on this?
do I just press the ac button and turn the temp control to cold?
never bothered with it but local garage has a cheap regas offer so don't want to look a fool if its working fine and its just me not operating it right
cheers
copey
PostPosted: Sat Jul 05, 2014 2:48 am Up
pretty much it press the AC button, turn it to cold......turn it up......see how cold it is
02 2.0 hdi d turbo
omega
PostPosted: Sat Jul 05, 2014 9:37 am Up
thanks
thought that was it but never had air con before
tried it and its not very cold so will try the regas.
1245678
copey
PostPosted: Sat Jul 05, 2014 12:55 pm Up
probably better off getting the air con serviced before re gassed
02 2.0 hdi d turbo
omega
PostPosted: Mon Jul 07, 2014 8:38 am Up
well went today and the offers finished so it will stay the way it is.
1245678
PostPosted: Mon Jul 21, 2014 6:15 pm Up
The thing with aircon is that there is lubricant in the fluid. If your car is low on fluid the seals will perish and the system will stop working completely with a big bill to fix. If you can afford it get a regas from a reputable aircon specialist. They should extract all the old fluid / gas and replenish.
