Online Now [84]:
Visitors: 83
Today: 102297
Total: 140095642
Forums › The Car › 206 Talk › gti 180 brakes
gti 180 brakes
Achie
PostPosted: Tue Jul 08, 2014 3:09 pm Up
I've got a 1.4 petrol 206, will the discs and calipers off a gti 180 fit, will they just be a straight swap or is there further stuff needed?? Any info is appreciated!!
Lex206
PostPosted: Tue Jul 08, 2014 3:19 pm Up
wont fit behind 14 inch wheels
Megane 225 RS
PostPosted: Tue Jul 08, 2014 3:23 pm Up
The 266 x 22mm vented front set up of a later GTI / XSI etc is a better upgrade for a 1.4, the larger callipers bolt straight on & will fit behind the 14" rims.
Achie
PostPosted: Tue Jul 08, 2014 4:03 pm Up
I've got 17" wheels on it, I'm looking at the gti 180 set up just because I'm hoping to do an engine conversion later on also,
PostPosted: Tue Jul 08, 2014 4:23 pm Up
Does your car have ABS? If it doesn't I'm sure the master cylinder is smaller than ideal.
Achie
PostPosted: Wed Jul 09, 2014 1:03 am Up
I think it does yeah, how would u tell fir definate if it has?
mtempsch
PostPosted: Wed Jul 09, 2014 10:38 am Up
You should have an ABS light in the instrument cluster that comes on w/ ignition for test and the goes out. Just right of the airbag lights and just below the fog lights indicators (in the angle between the fuel and rev gauges)
Or check the back of your wheel hubs for toothed rings and reader sensors...
(youtube has videos, and google images, of what they look like)
Or find a straight stretch of road and step HARD on the brake pedal (after checking there's no traffic behind you!).
If your wheels lock up and you leave black streaks and smoke behind you, you don't have ABS.
If the wheels don't lock up and there's no noise and smoke, but the brake pedal pulsates/vibrates under your foot - you've have ABS.
Silvermetallic 2004 206 RC
PostPosted: Wed Jul 09, 2014 1:51 pm Up
It's probably easier to just open the bonnet and look behind the passenger side headlight for a alloy block with some brake pipes going into it!
usher
PostPosted: Wed Jul 09, 2014 3:18 pm Up
What He Said
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Jul 09, 2014 3:43 pm Up
I lost interest in the thread soon as I saw engine conversions mentioned Laughing
Biggest waste of time & money going, why do people never learn Laughing
