Online Now [465]:
Visitors: 464
Today: 11872
Total: 142825387
Forums › The Car › 206 Problems › stolen car keys - reprograming & lock changing
irdaze
PostPosted: Wed Jul 16, 2014 9:00 am Up
hi all, was burgled last night the b******s took my bike,phone and the wifes car - I disturbed them or they would have emptied the house! i chased them but was naked! that will haunt them! BUT they stole my car keys for a 206 1.6 98 plate- now I need to know if i can replace all the locks myself and also remove the keys from " the cars memory" and then add new ones - cheers
and easy
MrWhite
PostPosted: Wed Jul 16, 2014 11:46 am Up
I would suggest a new Ecu Bsi and key fob along with new blades with your lock set. Unless mr Bsi knows anything im sure he would be able to give a better opinion.
My 206 Project Thread
PostPosted: Wed Jul 16, 2014 12:08 pm Up
This would be the cheapest option considering how old the 206 in question is & the fact non multiplexed remote fobs are no longer even available from Peugeot.
Replacing the lock set is easy enough, do you still have any keys for the car?
qwert
PostPosted: Wed Jul 16, 2014 3:39 pm Up
When you recode the new key it changes the immo code locked in the chip and BSI, hence why you need all existing keys when you are programming a spare!
brum brum
PostPosted: Wed Jul 16, 2014 3:56 pm Up
For a 16 year old 206 it's just not worth buying a new key or lock set for - new remote fobs are not even available from Peugeot for these any more either.
An insurance claim to replace the lockset would write this 206 of straight away.
The reason I asked about having any keys left for the car is you need the key to turn the ignition barrel in to the service position so you can remove it from the steering lock without having to resort to other more destructive means of getting the barrel out.
A complete second hand lock set with matching BSI & engine ecu is the cheapest fix for this 206.
PostPosted: Wed Jul 16, 2014 4:07 pm Up
I thought the security code was locked to the ECU and couldn't be changed, not even by Peugeot.
You can code a new key to the existing ECU/BSI using the security code, but this won't help the OP. You can also un-sync old keys from the car, but this is only for the remote fob so again wouldn't help the OP as you could still start the car if you had the correct key.
Second hand BSI/ECU/IMMO chip. Make sure you get the VIN from the donor vehicle and if possible the security code.
If you have a spare remote fob, then this could be recoded to the BSI so that remote unlocking works. You would still need a virgin chip programming to the ECU for your spare fob. The chips cannot be reprogrammed.
TBH, it might be better to let your contents insurance company sort everything out.
PostPosted: Thu Jul 17, 2014 1:10 am Up
Just get some second hand locks and a basic key, as when you code keys it wipes out the old ones if they arent present at coding. The plip on your old key may still work though with you bsi but they wont be able to start it!
PostPosted: Thu Jul 17, 2014 2:03 am Up
Is this only on pre-plexed?
I have had a new circuit board and chip coded to the car and a spare key that was 30 miles away at the time still unlocks and starts the car.
