Online Now [326]:
Visitors: 325
Today: 30283
Total: 142174469
Forums › The Car › 206 Problems › Spray painting interior panels
ollie_mason
PostPosted: Mon Jul 21, 2014 3:30 pm Up
Hi,
I tried/am trying to spray paint all the interior panels. I sanded it down mad went t apply the first coat, when the paint hit the surface it bubbled straight away, and only some of the paint actually stayed. Is there anything I can do to resolve this issue?
I could really use some help!
Thanks,
Ollie
Proud owner of a Peugeot 206 1.4 GLX
tomhollo21
PostPosted: Mon Jul 21, 2014 3:49 pm Up
Please say that you cleaned the surface first and applied primer and then gently sanded the primer and cleaned the surface again before actually painting
DeadEyePaul
PostPosted: Mon Jul 21, 2014 3:53 pm Up
Sand then primer (for plastic) use a high grit paper and sand smooth . Spray 2-3 coats of colour(allow to dry between coats) Allow to dry for 24hrs and again use a high grit paper then lacquer. Laquer takes longer to harden than colour so dont rush this final coat otherwise its back to primer
ollie_mason
PostPosted: Mon Jul 21, 2014 4:39 pm Up
ahh okay! Thanks alot!!
PostPosted: Mon Jul 21, 2014 5:50 pm Up
Also if you have previously polished this with some of the silicon polishes you will have a tough job to wash that off and it will make the paint bubble. Not sure what to recommend for that but someone here might help.
MrWhite
PostPosted: Tue Jul 22, 2014 7:18 am Up
Ok. I went full noob on mine and went straight to paint. Looks awesome too. Hope you have better luck Smile
My 206 Project Thread
Mr-Tigger
PostPosted: Wed Jul 23, 2014 9:55 am Up
does as advised abovre,take time and you'll be fine. i've never really sprayed and managed this
renault racing bleu
Only left about half hour between coats but before lacquering left for 3 hours in hot shed
ollie_mason
PostPosted: Wed Jul 23, 2014 11:56 am Up
renault racing bleu
Ahh okay, that looks nice! It's the same colour I am doing, but the paint has run.. Got to try and get that out!
tomhollo21
PostPosted: Wed Jul 23, 2014 12:00 pm Up
Only apply thin layers with the paint otherwise when it does run then you have to sand it back again
