Online Now [807]:
Visitors: 806
Today: 58166
Total: 146760849
Forums › The Car › 206 Problems › Dozen of symptoms together! Please help
hamed206
PostPosted: Sat Jul 26, 2014 4:31 pm Up
Erratic idling, hesitates on acceleration, not burning fuel, excessive gas consumption, exhaust smoke. ....all of these symptoms are permanently happening now significantly. I have no engine management light on. I had the coolant & MAP sensors changed plus the spark plugs during the last car service.
Something to mention, my spark plugs was fouled when I changed them last time.
Any help or advise?
Hamed
PostPosted: Sat Jul 26, 2014 4:37 pm Up
I would still get codes checked even if eml light is not on. A stored fault might point towards what problem is.
hamed206
PostPosted: Sat Jul 26, 2014 7:22 pm Up
I parked the car for 2 hours, now driving it no hesitation, no smokes, no smell of fuel, no more abnormal fuel consumption...it is just running smooth! I don't want this to happen again.
I had my car fueled to full tank today, does this has something to do with the problem? I lost 5-6 liters during few kilometers driving! And there were a smell of unburned fuel coming from the exhaust.
Hamed
ukskater01
PostPosted: Sun Jul 27, 2014 3:52 am Up
Sounds like a bad lambda sensor, you need to get Peugeot planet to see if any codes are there
hamed206
PostPosted: Sun Jul 27, 2014 7:27 am Up
I'm suspecting the Lambda as it is an aftermarket one and done about 70K miles.
Hamed
hamed206
PostPosted: Sun Jul 27, 2014 6:55 pm Up
Car is still idle erratically in the morning, and when hot...all the time! Sounds like a faulty O2 sensor.
Hamed
PostPosted: Mon Jul 28, 2014 9:00 am Up
Read the codes. Don't just guess and throw parts at it.
Do you have an exhaust leak?
PostPosted: Mon Jul 28, 2014 9:04 am Up
Could be defective MAP or a few other reasons including Lambda but guessing and throwing parts at it gets expensive very quickly.
hamed206
PostPosted: Mon Jul 28, 2014 11:17 am Up
I had an exhaust smoke (white smoke) when the symptoms were in the worst status. And a smell of unburned fuel. Not sure what do you mean by exhaust leak, if you mean a fault in the exhaust system like cracks, holes...etc, so no.
Hamed
hamed206
PostPosted: Mon Jul 28, 2014 11:18 am Up
Not sure if the old 206 models will show the exact fault on a diagnosis test. Usually all faults appear under the name "Mixture Regulation Function"
Hamed
