Latest: Kifi69
Overall: 17183
Online Now [342]:
Visitors: 341
Members: 1
Today: 52022
Total: 144069912
Forums › The Car › 206 Problems › cat removal
cat removal
marv88
PostPosted: Sun Aug 17, 2014 6:13 am Up
how is easy is it to remove the catalytic converter to replace with a new one, im a diesel/ heavy machinery mechanic so i can put up with the worst of jobs.
MrWhite
PostPosted: Sun Aug 17, 2014 7:14 am Up
its about 15 mins of a job to jack it up and cut off then im not sure how long depending on how much of a good welder you are.
that's the job done on mine
My 206 Project Thread
On which engine?
marv88
PostPosted: Sun Aug 17, 2014 8:51 am Up
2001 gti, 136. i see its all push and clamp fit
iainlovatt
PostPosted: Sun Aug 17, 2014 10:49 am Up
I'm slightly lost there too lol!
Its not that bad. Depends if you get lucky or not on the clamp bolt running off the manifold. that can be a pain. the other one doesn't tend to be as bad.
You may struggle getting the lambda sensors out then without a lot of heat.
(My Garage)
marv88
PostPosted: Sun Aug 17, 2014 10:51 am Up
yes not looking forwad to it
Project2062014
PostPosted: Tue Aug 19, 2014 8:44 am Up
It be easy !
