Online Now [108]:
Visitors: 107
Today: 10416
Total: 104983425
Forums › The Car › 206 Problems › 206 HDi Has some sort of compression lock ??
o2ace
PostPosted: Thu Aug 21, 2014 2:27 pm Up
Hi
Have just brought an accident damaged car, installed a battery and the engine just clicks, put the gear into 1st to see if the starter was jammed, but could not turn engine. The car is now over a pit where I managed to turn the car over using the crankshaft bolt until the engine locks, I think maybe when it gets to the compression stroke. Turning the car by key now turns the engine for about a second till its gets to the compression stroke. Any ideas what it could be, my only thought is that the car went into a ditch and swallowed some water, but not sure.
2003 1.4 Hdi
Thanks Dave
Seatock789
PostPosted: Thu Aug 21, 2014 3:50 pm Up
Hi Dave,
Best advice I can give is remove the spark plugs and then try turning it over, if it has swallowed water then you should be able to see it in the cylinders.
Steve
Seatock789
PostPosted: Thu Aug 21, 2014 3:56 pm Up
Sorry, remove the glow plugs and try.
southwestchap
PostPosted: Fri Aug 22, 2014 4:25 am Up
Does it stop dead? or does it go tight?
Could be a valve issue. As seatock says, you could whip the glowers out and try.
o2ace
PostPosted: Mon Aug 25, 2014 6:23 am Up
Thanks for the replies, have just taken the glow plugs out...what a nice job..not. Spun the engine over by hand and oil has come shooting out of the glow plug holes ???
Seatock789
PostPosted: Mon Aug 25, 2014 6:57 am Up
Sounds like a head off job to me, could be the rings are shot or something else. Is it oil & not diesel? See if you can suction the oil out and then try cranking it over and see if any more oil appears.
PostPosted: Tue Sep 09, 2014 2:03 pm Up
Not water contaminated with either deisel or oil?
