Online Now [86]:
Visitors: 85
Today: 2097
Total: 104952527
Forums › The Car › 206 Problems › Intermitant Acceleration by itself after changing down gears
esplace
PostPosted: Fri Sep 12, 2014 5:28 pm Up
Hi,
Hoping someone can give me a solution as seems no one at any Peugeot service centre's have any idea.
2004 206 petrol
After changing down gears "ie coming towards an intersection" foot of the clutch and accelerator, it sometimes takes off by itself, and quite dramatically, almost hitting a tree on two occasions.
It happens cold or hot, and seems to be more common now than a month ago.
I also note that the rev counter or speedo are not showing a great deal of movement when this is happening
Have changed the Fuel sender
Had all the fuel parts cleaned
Clutch bled
Accelerator sensor checked an ok,
Other issues that may have some relevance include "these are Intermitant also"
The brakes sometimes get more sensitive while at the same time the clutch gets sloppy, or the other way round but there seems the main issue isn't reliant on what happens here.
The gears clunk when the clutch is sloppy
Thanks for any help i may get,
qwert
PostPosted: Sat Sep 13, 2014 3:31 am Up
Have you checked your throttle position sensor?
brum brum
esplace
PostPosted: Sat Sep 13, 2014 4:59 am Up
Hi,
Thanks for your reply, and Yes, this was checked and ok,
Cheers
Ian
PostPosted: Sat Sep 13, 2014 5:05 am Up
Is it a mechanical or electronic throttle body?
esplace
PostPosted: Sun Sep 14, 2014 12:30 am Up
Hi Macca,
fly by wire, so electronic
Cheers
PostPosted: Sun Sep 14, 2014 4:49 am Up
Plug into PP2000 and do the actuator tests.
Could be a dodgy pedal sensor, dodgy TB, bad connection in the wires, software bug or possibly 1 of 100 other things, Without diagnostics it would be pure guesswork and you could spend a lot of money replacing items that are working perfectly well.
esplace
PostPosted: Mon Sep 15, 2014 1:14 am Up
Hi Macca,
Thanks for your help,
I am hoping to get the diag done next month, as i am about 2 hours away from the closest peugeot service centre,
I will post if i get some idea of what it might be
cheers
Ian
