Latest: lio94
Overall: 17181
Online Now [184]:
Visitors: 183
Today: 80503
Total: 141947533
Forums › The Car › 206 Problems › 206 gt rear axle problem
Gtscott
PostPosted: Fri Sep 19, 2014 2:08 pm Up
Hi can anyone tell me if my rear axle is going or maybe some advice what to look at as when no one is in the back the car is fine but as soon as one person sits in the back it makes a loud bang on speed humps potholes etc and sits really low the car is factory height the only mod is exhaust any advice would be great
badj
PostPosted: Fri Sep 19, 2014 2:12 pm Up
It should just as easily be shock absorbers, to be honest.
You'd have to have a look or take a photo or two.
The end plates can also shear on the end of the ARB. You'd notice this by looking.
General symptoms of a worn axle are excessive camber (cause by loose axle bearings) or 'creaking', whereas most other noises can normally be shocks or end plates, to be honest.
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
Gtscott
PostPosted: Fri Sep 19, 2014 2:29 pm Up
Thanks for the reply ill have a look over the weekend and try and upload some pics
Gtscott
PostPosted: Fri Sep 19, 2014 2:40 pm Up
Just had a quick look and both arb end plates are in tact and tight is there a way of checking the shocks i had the car at a tyre shop and he checked all bushes and only recommended front arb link arms
badj
PostPosted: Fri Sep 19, 2014 3:05 pm Up
The easiest way really is to just push down on the back of the car and try and replicate the sound.
Have you checked the spare wheel also, as the jack is normally in there and could be bouncing around
KMF '05 1.4 HDi
ukskater01
PostPosted: Sat Sep 20, 2014 5:25 am Up
My exhaust use to bang, think it was the wrong hangers, I knew it wasn't the axle as I put a recon axle on as the bearings had failed.
