Latest: jackrox1992
Overall: 17186
Online Now [355]:
Visitors: 354
Today: 188884
Total: 148330994
Forums › The Car › 206 Problems › How do I reset the Airbag warning light?
JordHaze
PostPosted: Tue Sep 23, 2014 9:33 am Up
Hey guys,
My old 206's Airbag Warning Light is on and I need to sell it.
How do I reset it?
I've checked all the connections, changed the Comms2000 unit, soft reset, ect.. Is anyone able to help?
Cheers,
Jord
My 206 Project Thread
PostPosted: Tue Sep 23, 2014 9:48 am Up
Plug into PP2000, identify the fault, fix it and the light goes out.
JordHaze
PostPosted: Tue Sep 23, 2014 9:50 am Up
I don't have PP2000, can't afford it aha
mattymj
PostPosted: Tue Sep 23, 2014 10:53 am Up
Check the pp2000 map
PostPosted: Tue Sep 23, 2014 11:08 am Up
What He Said
What was wrong with the old com unit OR did you just guess it was the fault?
PostPosted: Tue Sep 23, 2014 2:36 pm Up
That is why we have the PP2000 map ,click on the link below,and check who is close to you,as you could saved many by checking the fault code,instead of replacing parts that is not related to the actual cause.
www.206info.co.uk/Foru...55053.html
JordHaze
PostPosted: Tue Sep 23, 2014 3:17 pm Up
Just found out my Dad's bought a PP2000 type thing and I'll hopefully find the fault soon!
Maqer
PostPosted: Tue Sep 23, 2014 8:28 pm Up
The airbag is on the same fuse as the horn. I had mine come on for a while when the horn(s) rusted, one of the contacts on both was completely rusted. Had to replace them but the airbag light wasn't lit all the time.
jauraari @ gmail.com
A_T_C
PostPosted: Wed Sep 24, 2014 4:51 pm Up
hi , i have problem with crash data on Air bag ECU ... anyone have any Idea how can i remove it .. ? becuse it dosen't remove by Diag . i thught may be i can read EEprom IC data from healthy Air Bag ECU and over write that on Damaged ECU.. do you think it's use full?
PostPosted: Thu Sep 25, 2014 1:05 am Up
Replace the airbag ecu.
Jason
PostPosted: Thu Sep 25, 2014 2:52 am Up
Maybe the comm 2000 replacement is faulty if secondhand?
JordHaze
PostPosted: Sat Sep 27, 2014 10:27 am Up
Hey,
I used an "iCarsoft" diagnostics tool, was a fault with the driver's level 1 (I have no idea if that's what it's called, hopefully someone knows what it is).
My Dad and I got another Comms2000 unit and THE LIGHT WENT OUT!
So, we moved the car to take pictures of it so I can sell the heap... AND the light came back on. Same fault. What do I do now? How much for the part I need? New.
Cheers guys,
Jord
