Latest: jackrox1992
Overall: 17186
Online Now [934]:
Visitors: 933
Today: 126364
Total: 148888132
Forums › The Car › 206 Talk › Removing front wing inner wheel arch plastic - 206 GTi 180
Forum Index › 206 Talk
cheekyage
PostPosted: Fri Sep 26, 2014 12:43 am Up
Hi all,
Before I attempt to do this on my own I thought I would ask here and see if there is a suitable way to remove the plastic wheel arch lining from the front wing of a 206 GTi 180.
I can see there are 1 or 2 mushroom head/rivet type plastic clips.
Are there any special techniques to easily remove this?
Refer to attached pic below.
Vexs
PostPosted: Fri Sep 26, 2014 1:09 am Up
Other than the mushroom clip these are also connected to the front bumper, you will see a screw roughly directly below the fog light.
These are surprisingly flexible so what I tend to do is rotate it towards the back of the car slightly and then pull the horizontal tab that sits inside the bumper out below the bumper the it'll simply drop out from the wheel arch and then you can slide it out, really not a difficult job at all.
Also providing your car is not lowered there is no real reason for you to even jack the car up to get it out, but I guess that depends on why you need to remove it.
My GTI 180
My Old 1.4 8v
iainlovatt
PostPosted: Fri Sep 26, 2014 3:53 am Up
use a fork to remove the mushroom clips. Makes life easier! Smile
(My Garage)
PostPosted: Fri Sep 26, 2014 6:14 am Up
I use a screwdriver and circlip pliers to remove the plugs. You need to remove the wheel to access the plugs behind the wheel.
uttz
PostPosted: Fri Sep 26, 2014 6:15 am Up
well yours look like the 2 piece version, mine is the one piece. but there are 3 plastic clips, 2 either side of the strut and one if you look directly up. and 3 screws 2 on the bumper and one behind the wheel arch under the car.
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
