Online Now [554]:
Visitors: 553
Today: 173043
Total: 146627928
Forums › The Car › 206 Talk › Washer Jets are shocking
Forum Index › 206 Talk
206Mark007
PostPosted: Fri Sep 26, 2014 12:03 pm Up
Any ideas how i can make the front washer jets work better? They hardly fire any fluid out of them and ive been told its a common problem
Triggerfish
PostPosted: Fri Sep 26, 2014 1:04 pm Up
Usually they are blocked at the nozzle/outlets. You can use a long pin and poke into the nozzle/outlets to clear it. Slide it in and out and it will be cleared.
Check under the bonnet too to see if there are any blockages within the actual clear fluid pipes that leads to the nozzles/outlets. If so, detach pipe from nozzle/outlets to clean inside the pipes.
206: 1.1L, 2002.
mtempsch
PostPosted: Fri Sep 26, 2014 2:22 pm Up
If you with the nozzles detached still have poor flow, follow the line back towards the reservoir and check that it isn't kinked.
Is your rear washer also underperforming?. There could be gunk at the bottom of the reservoir [partly ] blocking flow into the pump.
Silvermetallic 2004 206 RC
gazza82
PostPosted: Fri Sep 26, 2014 6:22 pm Up
Fit the newer spray type ... Much better.
206Mark007
PostPosted: Sat Sep 27, 2014 9:48 am Up
Cheers for info guys ill have a look into this
