Latest: jackrox1992
Overall: 17186
Online Now [861]:
Visitors: 860
Today: 239350
Total: 148164402
Forums › The Car › 206 Talk › Reverse lights not working
Forum Index › 206 Talk
206Mark007
PostPosted: Sat Sep 27, 2014 9:59 am Up
Changed bulbs but no joy where is the fuse? looked on the forum is it f23 in the engine box 10amp fuse? as i dont know if the cars pre-plex or multi-plex as stated on here and i cant find it listed for mult-plex. Cheers in advance
PostPosted: Sat Sep 27, 2014 11:08 am Up
99% of the time it will be the switch, common problem & cheap from a Peugeot / Citroen main dealer.
Unplug the switch, short the connector plug terminals out on the loom connector & turn the ignition ON - if the reverse lights now work you know the switch if faulty.
2003 will be multiplexed.
206Mark007
PostPosted: Sat Sep 27, 2014 4:43 pm Up
cheers for info
andy83
PostPosted: Sun Sep 28, 2014 2:14 am Up
i also have the same problem checked the bulbs they were fine and fuse is ok, so id imagine its the switch as mrbsi has kindly pointed out
