Forums › The Car › 206 Talk › Whats the mm size in ARB? 206 1.4 |
Posted: Wed Oct 08, 2014 5:30 pm |
Basically as the title says, just wondering as powerflex do 2 bushes in different mm (20mm or 22mm).
206 1.4 8v 1999 Petrol.
Posted: Wed Oct 08, 2014 6:14 pm |
I'm pretty certain it's neither, it's 19mm on the 1.4's and even SB shows it up as 19mm diameter.
Posted: Thu Oct 09, 2014 1:13 am |
You need the grab the front ARB from an Xsi or Hdi GTi.
