Latest: Beduff1977
Overall: 17134
Online Now [679]:
Visitors: 679
Today: 163729
Total: 109158452
Forums › The Car › 206 Problems › Abs?? Help
Abs?? Help
Lee78
PostPosted: Fri Oct 10, 2014 3:44 pm Up
Hi all
Abs activating at low speed.no warning lights.
Light comes on/off as should at start.
Just had rear axle changed and used all the parts from the old axle brakes,sensors etc which never had problems with.
Rings I've cleaned on the front,not sure how to do the rear.
Cleaned abs sensors on the back but,can't get front ones out.
Thanks in advance
PostPosted: Sat Oct 11, 2014 1:30 pm Up
usually when the ABS kicks in at low speeds,it's because there is dirt covering the sensor,a good clean will fix this.
