Online Now [122]:
Visitors: 121
Today: 83308
Total: 142896701
Forums › The Car › 206 Problems › Oil leak
Oil leak
callum_88
PostPosted: Tue Jul 15, 2014 3:41 am Up
hi im new to the forum and after some help please! I bought my 206 in feb this year its 2002 model, iv had nothing but trouble replaced comms 2000 and battery and radiator! all separate problems. and now I have noticed an oil leak its coming from the bottom where the engine joins the gearbox it appears to be engine oil although the oil is light in colour it has no smell
any help as to what this could be and rough costs greatly appreciated
thanks
ukskater01
PostPosted: Wed Jul 16, 2014 5:05 am Up
Could possibly be your rear crank seal, has your clutch been slipping? Have you had anyone to look at it yet?
PostPosted: Mon Jul 21, 2014 6:04 pm Up
Is the oil on your dipstick the same colour? If your dipstick oil is darker then what is leaking is probably gearbox oil.
Mattsard
PostPosted: Fri Oct 10, 2014 10:25 am Up
My friends just bought a 2005 1.1 206 and it appears to have this oil leak, it's defo engine oil rather than gearbox oil. Rear crank seal you think?
PostPosted: Fri Oct 10, 2014 11:07 am Up
Degrease / clean the leaked oil of the engine so you get a clue as to where the leak is coming from.
If your using a pressure washer DON'T aim it at any of the electrics & also make sure the engine is stone COLD.
Oil leaks can be hard to find unless you see actually the leak in action, I normally find starting with it clean helps pinpoint the leak.
uttz
PostPosted: Fri Oct 10, 2014 8:31 pm Up
Sounds like rear engine seal. gearbox has to come down to change this
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
206HdiGti
PostPosted: Mon Oct 13, 2014 5:18 am Up
I had this happen on my HDI.
It hadn't gotten to the stage of dripping but thankfully found it when changing my clutch and DMF.
Unfortunately the box has to come off, but when it's off you might want to clean the back of the flywheel as there WILL be oil on this.
Mine was covered in it, perhaps one of the many reasons it was fubar.
It's very easy to change the rear main seal, unfortunately I wasn't expecting this to be here, so a very quick 120 mile round trip and £22 later it was all fixed!
