Latest: Kifi69
Overall: 17183
Online Now [537]:
Visitors: 536
Today: 31650
Total: 144491483
Forums › The Car › 206 Problems › Noise from back
Noise from back
jamie-38-206
PostPosted: Tue Nov 11, 2014 12:16 am Up
Hi, My car had a lot of work done to it recently due to failing MOT and other issues. My mechanic put a 2nd hand rear axle on it but there is a squeak coming from it. it does it when you push the back of the car up a down also. I took it back and he said it is the torsion bar and its just one of those noises you get from old peugeots. it is very annoying. What can be done about it? Is a new torsion bar a option? or can it be greased or something?
206 1.4 - 2004 (TU3JP)
Vexs
PostPosted: Tue Nov 11, 2014 1:40 am Up
A new torsion bar is an option, there not that expensive at all.
Is your mechanic 100% sure its even suspension related? Could just be the space saver cage?! Mine was squeeking until I removed the thing.
My GTI 180
My Old 1.4 8v
jamie-38-206
PostPosted: Fri Nov 14, 2014 12:06 am Up
just checked mate. its not the cage..
Oafie
PostPosted: Fri Nov 14, 2014 6:38 am Up
sounds like you've got a dry bearing on your axle mate,
not sure if it can be greased without stripping the arm off tho .
if your going to do that I'd change the bearing at the same time, they're not that expensive.
southwestchap
PostPosted: Fri Nov 14, 2014 7:57 am Up
Bearing is cheap and not too bad to do. Its getting to it that's the issue.
PostPosted: Fri Nov 14, 2014 2:08 pm Up
Does it squeak with the handbrake off?
jamie-38-206
PostPosted: Sat Nov 22, 2014 3:52 am Up
Yes, is makes noise when moving and when you push it up and down when stopped. Even made it when i got out of the car. I thought i was slim Wink
Oafie
PostPosted: Sat Nov 22, 2014 9:22 am Up
sounds's like a failing bearing/ rear shock
