Latest: tbafonso
Overall: 17130
Online Now [296]:
Visitors: 295
Today: 72375
Total: 104261991
Forums › The Car › 206 Problems › Peugeot 206 Gti 180 horn problem
Lloydy47
PostPosted: Sat Nov 15, 2014 2:27 pm Up
Hi, Had a problem with my horn it stopped working then came back again, now it has stop again taken steering wheel off and all looks ok, fuse under bonnet fuse box ok but replace with new anyway. Press the horn and you can here clicking around the fuse box area, taken bumper off and check horn with a separate battery all ok brought a new second Hand horn check with battery as well all ok swapped over and still does not work ? Please help Cheers Andrew Rolling Eyes Crying or Very sad Mad Evil or Very Mad Twisted Evil P.S is there a relay anywere if so we're ?
PostPosted: Sat Nov 15, 2014 2:54 pm Up
Its normally the wiring down to the horn that is the issue, the wiring can look perfectly fine until you strip the insulation back & find its all green & rotted.
Lloydy47
PostPosted: Sat Nov 15, 2014 3:59 pm Up
Cheers will have a look at it tomorrow, P.S One more thing if i press the horn with the fuse in or out i still have the clicking in the fuse box area and still no horn, is that rite ? Cheers once again Andrew
