Latest: lio94
Overall: 17181
Online Now [164]:
Visitors: 163
Today: 70310
Total: 140547441
Project sleeper
Go to page Previous  1, 2, 3 ... 68, 69, 70 ... 85, 86, 87  Next
PostPosted: Wed Oct 08, 2014 4:18 pm Up
Well I ordered my throttle body spacers yesterday and they arrived today.
I realised today I actually have 45mm bodies but I thought they were 42mm. Even though I have 42mm air horns and spacers they still flow more than enough air for the engine.
£98 delivered and should hopefully bring the power band further down the Rev range. I now have an extra 60mm of intake length compared to when the engine was set up.
samversteeg
PostPosted: Wed Oct 08, 2014 5:18 pm Up
The spacers are pretty smart.
How long is your intake now?
Im on 31cm right now without headlenght.
The powerband is from 5.000rpm till 7500rpm.
Although the torque is dropping fast after 6.000rpm.
andy83
PostPosted: Thu Oct 09, 2014 11:18 am Up
gotta love a thottle bodied set up, and what a great place for them to be positioned should get decent air flow there
you have got a really good set up there going off your spec fella, what power are you making atm?
PostPosted: Thu Oct 09, 2014 12:29 pm Up
Don't ask Tedward about power figures...
Project2062014
PostPosted: Thu Oct 09, 2014 4:54 pm Up
What does it make ? 170 bhp ?
PostPosted: Fri Oct 10, 2014 3:37 am Up
Less than that because he hasn't got 180 injectors, everyone knows you need them to break the sound barrier.
PostPosted: Fri Oct 10, 2014 5:17 am Up
Oh but I do have them fitted....
PostPosted: Fri Oct 10, 2014 1:17 pm Up
What happens if you have ones bigger than 180 injectors? Does time go backwards?
PostPosted: Fri Oct 10, 2014 2:34 pm Up
Sorry Edward!
You better ask project about the quantum physics regarding injector size!
PostPosted: Sat Oct 11, 2014 7:42 am Up
I'm on pretty similar. 90mm airhorns, 9.5mm spacers, TB's are 118mm long and according to the Jenvey website the manifold is 98.8mm long. So it looks like I have more or less 320mm. Allowing for maybe 50mm from head flange to inlet valve it's about bang on what Jenvey recommend for a 7300rpm engine.
PostPosted: Tue Nov 18, 2014 4:36 pm Up
More money spent yesterday. £168 for a proper Jenvey throttle linkage and a new throttle body lever.
Getting the old lever off the throttle body is a little bit difficult though. Its held on with a tiny grub screw and I suspect it's also glued in place. Predictably this make them much more likely to get rounded off. I imagine it will have to get drilled out unfortunately.
macj
PostPosted: Sat Nov 22, 2014 12:46 pm Up
Good mod there Paul.... it is a better set up for the throttle and the cable routes nicely.
PostPosted: Sat Nov 22, 2014 1:38 pm Up
It looks a lot neater. It's just a bit fiddly to fit. Nearly done though. Will probably keep the standard throttle cable.
andy83
PostPosted: Sat Nov 22, 2014 1:42 pm Up
love this motor top work matey
PostPosted: Sun Nov 23, 2014 4:14 am Up
Almost finished now. Just need to sort the cable. The supplied cable fits the linkage but the other end doesn't fit with the standard Peugeot attachment on the throttle pedal. Can't be too hard to resolve it though.
Next job will be the fuel rail. I want to shift the injectors into the bodies and get a Jenvey fuel rail with Aeroquip fittings and braided hose. There's a connection in the standard Peugeot fuel hose that's behind the drivers side wheel. If I can get an adaptor to fit the standard fitting it will make life easier.
Page 69 of 87
