Online Now [1054]:
Visitors: 1053
Today: 13104
Total: 149092902
Forums › The Car › 206 Problems › rear wheel bearing How to diagnosis which one faulty?
Cypriot
PostPosted: Sat Nov 22, 2014 4:04 pm Up
Hello,
I found out that one of the rear wheel bearing on my 1999 206 1.9D is gone bad. There's a loud whinning noise while driving and it's coming from the rear.
There is no noise when the car jack up and rotates tyres on the air
This whinning noise start after 20 - 25mph and get loud. The interesting thing is whe I turn left, the noise goes away.
When I turn right or go forward, the noise is still there.
Would this indicate a bad left or right rear wheel bearing?
Cypriot
macj
PostPosted: Sun Nov 23, 2014 6:25 am Up
Bad left one..... but replace both of them as the other will probably fail soon
Cypriot
PostPosted: Sun Nov 23, 2014 6:38 am Up
Thank you mate,
I already bought one for rear left (which I was suspect it is the worn side) but I 'll buy another and replace both rear.
By the way the dimensions of the peugeot 206 rear wheel bearings as follows;
Outer diameter : 52mm
Inner diameter : 25mm
Width. : 37mm
macj
PostPosted: Sun Nov 23, 2014 6:43 am Up
Cypriot wrote:
Thank you mate,
Width. : 37mm
I1ll take your word on that then Smile
Cypriot
PostPosted: Mon Nov 24, 2014 2:03 pm Up
Hello
I couldnt wait to buy for right side and replace rear left wheel bearing. Vehicle very silent. But I can easily hear clicking noise from front (suspension I think) when driving car rough roads.
I should find out what makes those clicking noises.
macj
PostPosted: Mon Nov 24, 2014 2:59 pm Up
Drop link if its knocking over bumps
