Latest: lio94
Overall: 17181
Online Now [79]:
Visitors: 78
Today: 48289
Total: 141430874
Forums › The Car › 206 Problems › Lost Coolant pipe clip
doski
PostPosted: Sat Nov 29, 2014 3:37 pm Up
Hi all I have a 1999 1.1 206 and after a thorough flush out of the coolant to top it back up I know realised I should've searched earlier for that clip that flew down the engine bay.
Basically at the bottom of the expansion tank there's a hose that points down and I've lost the jubilee/cir clip thats holds it on I've drove it and it seems ok just don't want it to pop off.
Anyone know what I need or where I could buy one from?
PostPosted: Sat Nov 29, 2014 6:04 pm Up
If it's only a jubilee clip then any good accessory shop will have them in. I even think places like Poundstretcher and Home Bargains have them in as a set of 5 or 6 in various sizes.
PostPosted: Sun Nov 30, 2014 5:43 am Up
If it's a black clip. It's part of the pipe. You'll have to order a new pipe from Peugeot. Did the same last year on a small Pipe that leads to the radiator.
PostPosted: Mon Dec 01, 2014 10:56 am Up
It will need a clip and either a small jubilee or equivalent will suffice, just dont overtighten and the tank is plastic and can be broken.
As temp build up so does the pressure in the system and may cause a leak here.
PostPosted: Tue Dec 02, 2014 7:48 am Up
I've got a whole pipe which had only been on the car for 3 months from new. Comes with clip too. I think it's the same on all earlier 206's.
