Latest: Beduff1977
Overall: 17134
Online Now [412]:
Visitors: 412
Today: 220862
Total: 107880888
Forums › The Car › 206 Problems › anyone from the Blackburn area with pp2000???
206gt160
PostPosted: Mon Dec 08, 2014 8:15 am Up
As above are there any kind people that could link there pp2000 to my car to see what seems to be the problem with my car not starting.
PostPosted: Mon Dec 08, 2014 12:12 pm Up
Just a normal fault code reader would help.
206gt160
PostPosted: Mon Dec 08, 2014 3:58 pm Up
They don't work on my 99 v reg Gt, had a few different readers and all say linking error.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
MrWhite
PostPosted: Tue Dec 09, 2014 4:12 am Up
I know someone who has is but not sure how much they charge. They deal in axles but I'm will ask and see if they can do the reading. Based in Padiham
My 206 Project Thread
PostPosted: Tue Dec 09, 2014 6:29 am Up
You wont get connected with an aftermarket scan tool if the car is immobilised.
206gt160
PostPosted: Tue Dec 09, 2014 7:46 am Up
Yes if you could find a price that would be great.
206gt160
PostPosted: Tue Dec 09, 2014 7:51 am Up
This was checked when the car was running and starting up first time, I have not tried to link an aftermarket one since the summer time.
Definitely does not link with any though, think only 2001 and on 206 link with a hand held reader. I have a maxiscan ms509 and it will pick up the Audi just never links to the pug. I don't think the 99 model 206 was obd2 compliant
MrWhite
PostPosted: Thu Dec 11, 2014 12:55 pm Up
Spoke with them today Just tell them when you ring that Nathan From the 206 forums Has told you to call. It should cost around £20 to read the car and if they are able to fix the fault they will let you know how much (If applicable) before anything gets done. 0800 9788 190 Axle Direct
206gt160
PostPosted: Thu Dec 11, 2014 3:46 pm Up
Thanks a lot mr white, I shall be calling them if I don't get to the bottom of the problem Saturday morning. Thank you.
