Online Now [287]:
Visitors: 286
Today: 40220
Total: 142083699
Forums › The Car › 206 Problems › 206 Gt will not start.
usher
PostPosted: Tue Dec 09, 2014 12:17 pm Up
souns like imob same as i had but with mine i replaced the whole loom lol not good advice but had the same issue with fuel coming but no spark, my issue was from cutting wires tho,
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
206gt160
PostPosted: Tue Dec 09, 2014 12:58 pm Up
It's just random how it has suddenly got an imobiliser problem whilst going round a corner, I will go and charge the battery on Saturday and then see if she starts. The battery connections are off ready for trying on Saturday.
Need to check I haven't got any wires rubbing or breaking.
I've read that you just keep the battery disconnected over night and charge the battery full, and then reconnect and start car?
Is it this simple?
Project2062014
PostPosted: Tue Dec 09, 2014 6:24 pm Up
It worked .cut out & runs but wont start off the key? So you can bump it ? Dead battery ?
206gt160
PostPosted: Wed Dec 10, 2014 2:59 pm Up
no the car ran, then when I was going around a corner it decided to cut out and has not started since. I was on about the pump was working then stopped working temporarily and when I disconnected the battery and cleaned up the multifunction relay and then reconnected the battery the pump started working again. I tried bumping it when it first cut out with no joy what so ever. it may be a dodgy battery but it started first time everytime without any hesitation for the 2 days I was driving it?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
oldskoolz
PostPosted: Thu Dec 11, 2014 8:07 am Up
as someone previously said I would check the earth strap. had a similar issue on my old 1.4, would start fine 80% of the time but other times nothing. earth lead was very very thin, after replacing it the car was fine
Black 206 Gti. Soon to be 2.2
206gt160
PostPosted: Thu Dec 11, 2014 11:28 am Up
I will be having a look at it again on saturday and i'll remove all the bonding lead and clean them up and check for damage. Fingers crossed though it may start up first time after resetting the imobiliser with having the battery disconnected and charged.
PostPosted: Thu Dec 11, 2014 2:57 pm Up
If the car was running when it cut out it won't be immobiliser, you'd also have the engine light if it was when trying to start. Does the pump run constantly when connected to the battery directly?
206gt160
PostPosted: Thu Dec 11, 2014 3:56 pm Up
Yes the engine light is on when the ignition is on, I will have to go and check what other lights may be on Saturday. Not sure I hav not checked that as of yet. Will it sound like it is constantly priming if i connect straight from the battery?
PostPosted: Thu Dec 11, 2014 4:01 pm Up
That's normal, it wont go out until the engine is running.
PostPosted: Thu Dec 11, 2014 4:06 pm Up
Yeah it will run constantly. Eliminates that as faulty if it runs. Does it always prime?
206gt160
PostPosted: Thu Dec 11, 2014 4:10 pm Up
Yes it always primes I've checked by pressing the Shrader valve and having fuel come out each time, also I can hear the pump prime.
Is the battery light always on before starting the car? When you turn the ignition on
206gt160
PostPosted: Thu Dec 11, 2014 4:14 pm Up
Thanks bsi
PostPosted: Thu Dec 11, 2014 5:01 pm Up
This might be a long shot, does the GTi have the shut off solenoid in the engine bay which is supposed to shut the engine off in the event of an accident? These have been known to trigger by going through pot holes and over speed bumps.
206gt160
PostPosted: Thu Dec 11, 2014 5:03 pm Up
Hey macca yes I think it's an inertia switch, I have tried it a few times and noticed it doesn't press then depress like a button should, I'm going to the breakers to get a new one Saturday. May be faulty. Does your 206 red inertia switch press and depress after pressing it?
PostPosted: Fri Dec 12, 2014 4:43 am Up
What plate is the car
Page 3 of 6
