Online Now [695]:
Visitors: 694
Today: 29863
Total: 142174049
Forums › The Car › 206 Problems › 2005 1.4 sohc petrol cam sensor
Iain1973
PostPosted: Tue Dec 16, 2014 8:02 am Up
Afternoon all. My sons car has recently had the MIL light come on with the fault code P1336 which should be cam/crank sensor fault. I've changed the crank sensor and the MIL light came on again shortly after. Can anyone tell me where the camshaft sensor is on the engine as I can't find it!!!
Cheers in advance
Iain
PostPosted: Tue Dec 16, 2014 8:31 am Up
8 valve by any chance? If so it's in the coil pack
PostPosted: Tue Dec 16, 2014 11:44 am Up
Are you sure it isn't just a poor connection on on eof the sensors or wire intermittently shorting to earth?
Iain1973
PostPosted: Tue Dec 16, 2014 2:29 pm Up
Yep 8 valve , is it easy to get at ?
