Online Now [295]:
Visitors: 295
Today: 112688
Total: 142380730
Forums › The Car › 206 Problems › 206 Gt will not start.
Go to page Previous  1, 2, 3, 4, 5, 6
206gt160
PostPosted: Wed Dec 17, 2014 3:16 pm Up
if the belt slipped would the cams still turn, I would of thought bent valve may get in the way?
Never expierienced it so I really dont know
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Wed Dec 17, 2014 3:21 pm Up
If there were some teeth missing on the belt then I would imagine it would still turn but not as quick.
206gt160
PostPosted: Wed Dec 17, 2014 5:50 pm Up
As it is now the only thing turning the cams is the starter motor, so it wont be spinning them at idle speed until the engine starts straight after ignition
PostPosted: Sun Dec 21, 2014 4:03 pm Up
Any update?
206gt160
PostPosted: Mon Dec 22, 2014 10:11 am Up
Not had chance to look at the car with it being nearly Christmas. It's been hectic
sean.r.steward
PostPosted: Mon Dec 22, 2014 10:30 am Up
Sould like it could ne a crank sensor
206gt160
PostPosted: Wed Dec 24, 2014 6:20 am Up
Ordered a new crank sensor and multifunction relay for £38.82, so by the 30th I should hopefully have the car firing up again.
PostPosted: Wed Dec 24, 2014 3:04 pm Up
Is that just a guess or have you read the codes? Have you tried what I suggested to fault find? Throwing parts at it will quickly get expensive.
206gt160
PostPosted: Sat Dec 27, 2014 2:06 pm Up
Yes I have fault read and found the crank sensor fault and as for the relays they go all the time and was only £15 so I decided to get myself one for a spare.
PostPosted: Fri Feb 06, 2015 2:50 pm Up
Did this ever get resolved?
Page 6 of 6
