Latest: jackrox1992
Overall: 17186
Online Now [724]:
Visitors: 723
Today: 109218
Total: 148638213
Forums › The Car › 206 Problems › 206 1.6 16v car has isuse's
danmoy
PostPosted: Wed Dec 24, 2014 6:43 pm Up
Need some advice, my 206 16v 1.6 has started to have starting probems ,it takes a few turns of key to start,its even worse once warmed up to start,and when driving tends to judder and if floored once it hits 4k rpm then sounds like VTEC crossover,in traffic it it starts to over heat
Vexs
PostPosted: Thu Dec 25, 2014 12:43 am Up
Start up issues I'd be looking at things like battery, spark plugs, coil pack.
Good way to test this would be to overload the car before the final ignition turn, so stick AC/CC on, radio, rear window heater, any and everything electrical and then see if it takes more turns then normal to start. If it does then possible battery issue, if it doesn't then spark plugs or coil pack likely to be at fault.
Over heating could be a few things, start with making sure the fans are kicking in when they should. What sort of temps are we talking to?
Finally multiplex or pre plex out of interest for the sake of not
having to ask later?
My GTI 180
My Old 1.4 8v
Lecktorious
PostPosted: Thu Dec 25, 2014 4:00 am Up
Trade Rating: +59
Sounds like a bad earth.
'98 Nile Blue 306 GTi 6
danmoy
PostPosted: Sat Dec 27, 2014 4:23 pm Up
New water pump and radiator and a set of spark plugs and its running fine.whats multiplex etc
