Latest: jackrox1992
Overall: 17186
Online Now [1048]:
Visitors: 1047
Today: 29308
Total: 148797422
Forums › The Car › 206 Problems › 206 Verve 2003 Leaking on Front Passenger side
snowy
PostPosted: Sat Dec 27, 2014 5:17 pm Up
Hi,
I've had my 206 for 2 years now and last year it leaked at the back passenger side door, we solved this by a bending the door slightly as it seem to not be closing properly, the was a massive gap between the door and the body and also, im told, we duct taped up the membrane behind the door card which seemed to do the trick.
A year later it begins leaking, this time from the front, we've already duct-taped the membrane back on, taping all around the edges to make sure the water doesn't flow out of the door into the car but it's still leaking. I've checked the drainage hole in the door and it seems to be clear.
The seal isn't very worn looking either but there definitely seems to be a small wet trail leading from the front corner of the seal down the plastic-rubbery edging and into the carpet, it is a very slight trail whenever I've seen it and the entire passenger footwell is soaked through.
Any ideas?
Vexs
PostPosted: Sat Dec 27, 2014 5:55 pm Up
Are you sure its definetly water and not coolant?
My GTI 180
My Old 1.4 8v
snowy
PostPosted: Sat Dec 27, 2014 6:02 pm Up
I can't say i'm entirely sure, however when it first began to leak there was a huge puddle, talking a few inches deep. Which appeared after I'd driven it for the first time in a few weeks, it usually sits on a 20 degree or so decline so i assumed that when I drove it the water flowed out. Since then there's been no huge pool just a continuously wet carpet having dried it out.
Vexs
PostPosted: Sat Dec 27, 2014 6:14 pm Up
Hmm a few inches deep is a lot of water to accumulated from a small gap in a seal, and I guess would be possible depending on how much rain fall you've had in the time it hasn't been driven.
Dry it right out, and when it happens again try and collect a sample and see what it smell/looks like, you would be able to tell if it's water or coolant by smell alone and colour to clarify.
Keep an eye on your coolant level too as if you're loosing some you'll end up with more issues as a result.
For your sake I would hope it is rain water and not the heater matrix.
If you're planning any long journeys that can't be avoided then take a bottle of coolant with you to be safe.
My GTI 180
My Old 1.4 8v
Lecktorious
PostPosted: Sat Dec 27, 2014 7:39 pm Up
Trade Rating: +59
Sit in the car and get someone to hold a hose on the area of the car leaking and check where it is coming in. Have you checked the drains below the scuttle panel to make sure they are clear?
'98 Nile Blue 306 GTi 6
PostPosted: Sun Dec 28, 2014 3:24 am Up
If you have a front mounted aerial, check the roof lining to see if it's damp. Normally the water just drips on the gear stick but if the car is parked on a slope, then it could run anywhere.
