Online Now [1091]:
Visitors: 1090
Today: 208663
Total: 149275947
Forums › The Car › 206 Problems › 180 ticking
180 ticking
lisa206
PostPosted: Sun Dec 28, 2014 2:32 pm Up
Hey all, I have just bought a 180 yesterday. But I am a bit worried , the car drives fine, but when the car is running but stationary , there is a ticking noise that happens about once every 30 seconds. It sounds like its coming from the bottom of the engine bay. But I have no idea what it could be , any ideas ???
LISA 206 180
Project2062014
PostPosted: Sun Dec 28, 2014 8:10 pm Up
Hi . My thoughts are as follows :-
It might go tick tick boomb one day !
Who knows with out looking .
I heard a badger the other day .
It didnt sound right but sure looked ok .
If only i could of taken it to the vets or that cheep service pdsa ?
8-( poor badger .. now il never know .
PostPosted: Sun Dec 28, 2014 10:31 pm Up
Without hearing it for ourselves, it is difficult to diagnose.
Possibly exhaust or heat shield expansion.
Possibly something to do with the aircon clutch engaging/disengaging
Possibly a relay clicking.
Is it audible when you are sat inside the car? Windows up?
Is it happening when hot/cold/all the time?
Engine at idle/fast idle?
Front/back/left/right of engine bay?
lisa206
PostPosted: Mon Dec 29, 2014 8:22 am Up
Its coming from bottom left of the engine, if your facing the front of the car.
only happens when its at idle, when it ticks, the idle drops a fraction, then it ticks again and the idle returns to its normal position.
Happens all the time regardless if its hot or cold. Can be heard in the car slightly but much louder when outside the car.
This is quite a loud tick, nothing a relay could produce imo.
Dont think its the heat shield or exhaust warming up as said happens when its cold and when its hot.
My thoughts are the a/c clutch? is this located at the bottom left part of the engine bay, towards the front grill??
LISA 206 180
broadblaster
PostPosted: Mon Dec 29, 2014 11:36 am Up
as you have said yourself it sounds like the A/C cutting in and out. just turn all the heater/a/c controls to the off postion and then see if it does it.
on a back road playing
Project2062014
PostPosted: Mon Dec 29, 2014 12:02 pm Up
My 180 dont click with ac on /off & idle dont move .. gti does ! Tick click ...
broadblaster
PostPosted: Mon Dec 29, 2014 12:13 pm Up
Both of mine did have quite a loud "click" and slight drop in rpm maybe mine were a bit more worn than yours who knows but still worth a try to see if it stops the clicking lisa206 is hearing.
Project2062014
PostPosted: Mon Dec 29, 2014 12:18 pm Up
i expected the 180 to drop the engine temp with ac on like my gti does but nothing 8-(
lisa206
PostPosted: Mon Dec 29, 2014 2:27 pm Up
I have tried turning the a/c off and when I turn it off , I don't hear the ticking but when its on I do , so its obviously the a/c causing it to tick :/
LISA 206 180
broadblaster
PostPosted: Mon Dec 29, 2014 2:36 pm Up
just the A/C clutch cutting in and out then so nothing to worry about.
Project2062014
PostPosted: Mon Dec 29, 2014 11:18 pm Up
Ive got a dogey car .
Thanks lisa Lol .
mine dont do anything !
Aircon works .. i
s this linked to dogey com unit anyone . Mattyj ?
